Is it true that newer MB and CD/DVD's no longer need the sound cable that used to run from the CD to the Soundcard?
I have read that all you need these days is to enable "Use digiatal sound" on the properties page in Device Manager and all sound will goe through the Ribbon Cable? Is this true?
I bought an OEM CD/DVD and want to know before I build if I should run out and get a sound cable for it.
Thanks !
Thanks !
