G
Guest
Guest
Archived from groups: microsoft.public.win2000.dns (More info?)
I cannot get PC's to find the DC. There are no firewalls or anti-virus. I am
on a lab network. I think when AD is implemented, the DC should register
itself with DNS. It seems to not do so. Using ipconfig /flushdns and then
ipconfig /registerdns states that the commands worked but still no success.
In the forward zones I do have the _msdcs, _sites _tcp, and the _udp files. I
believe these are the SRV records and they seem to be in order. There is no ".
" record in my forwad zone.
I can ping the DC's IP
I can ping the DC's domain name
I can ping the DC's FQDN
Ipconfig/all from the PC shows the DNS IP and name.
nslookup shows the IP but says there is no DC matching the IP.
netdiag /debug displays the DNS information of the DC and it seems to be in
order, showing the DNS name and IP. The only thing that doesn't pass is the
gateway but there is none.
This is the third or so attempt. The first attempt was on a live network and
I tried to join 21 PC's to the domain. It was fine untill I got to the 19th
PC and I started to get the message "cannot find domain name". No matter what
I do now I still get this message. Even on the lab network and after several
demotions and promotions of AD.
Any advice would be appreciated. Many have tried to help before and I
appreciate the effort.
QUESTION: one thing I haven't asked.......are my zone records supposed to be
listed as Active Directory instead of Standard Primary? It is my
understanding that they should only be placed in Active Directory if there is
more than 1 DC in the network so that the DC's can replicate info. I only
have 1 DC.
Several tries ago I got a PC to join AFTER I took Norton completely out of
the PC. I then put the PC back into a workgroup to see if I could re-join the
domain. It would not. It's been the same message ever since. Is my place
haunted???
Bill...goin nuts....S.
Message posted via WinServerKB.com
http://www.winserverkb.com/Uwe/Forums.aspx/windows-2000-dns/200507/1
have 1 DC.
haunted???
