Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Question on water cooling
Forum Overclocking : Cooler and Heatsinks - Question on water cooling
I currently have a swiftech water cooling and I thought of installing it first in my old machine and then in my new one. If I install it in the old one can I afterwards remove it and keep the water in it?
I have spare loop should it be need as they are different cases.
Sponsored Links
So basically you're asking "should I waste my time or not?" Common sense says put the best with the best.
Reply to 4Aces
Quote :
I highly doubt that the tubing will be the same length from case to case so you will probably have to take it apart.
Just put it in your new machine and run the loop without power to anything except the pump and the fans on the radiator over night to test for leaks.
Reply to waylander
There are 1279 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
