Hi there,
I've been doing some research lately on trying to configure a new system. I plan to use it for mainly high-definition gaming (Oblivion and other games that are more on the graphic-intensive side), and occasional movie watching. Was wondering if the following list of components would make for a great system that will last a few years before having to do major upgrades:
Case: Lian Li PC-60BPLUSII W Black Aluminum ATX Mid Tower Computer Case - Retail
Motherboard: ECS KA3 MVP (V1.0A) Socket AM2 ATI CrossFire Radeon XPRESS 3200 ATX AMD Motherboard - Retail - Not the best of brands, but not sure which board to use with an ATI card.
Video card: ATI Radeon X1900XT - Partial to ATI, so I'd prefer to stick with them.
Power supply: OCZ GameXStream OCZ600GXSSLI ATX12V 600W
CPU: AMD Athlon 64 X2 4200
Memory: CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800 (PC2 6400) - Might consider a cheaper alternative as the price keeps going up these days...
Floppy: SONY Black 1.44MB 3.5" Internal Floppy Drive
Hard drive: Seagate Barracuda 7200.10 (Perpendicular Recording) ST3250620AS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s
Monitor: SAMSUNG 930B-BK Black 19" 8ms LCD Monitor - Looking at this lately b/c of out-of-stockness.
Optical drives: http://www.newegg.com/product/product.asp?item=N82E16827101131
http://www.newegg.com/product/product.asp?item=N82E16827152058
Sound card: Creative Sound Blaster Live! 24bit 70SB041000000 7.1 Channels 24-bit 96KHz PCI Interface Sound Card - Retail
A few questions: I'm aware of Intel Core 2 Duo processors, but is it really worth it for the average home user over the selected AMD? I don't really have a preference for AMD/Intel, though the AMD is appealing because of higher-than-average performance, and the Intel can offer much greater performance, but at a bigger cost. I said earlier I'm not going to be buying for several months as I don't have all the money yet, so would you all think that the Core 2 Duo CPUs and motherboards would be more affordable by then to make up for the AMD CPU? On the other hand, AMD and ATI solutions would probably be better together because of the recent merger, but that's kind of in-the-clouds currently.
As for motherboard, I'm not planning on Crossfire, and would still like something that has a good chipset that would work well with my selected components. I shyed away from the nVidia chipsets because I thought there might be compatability issues with the video card, but I don't know about how chipsets work really.
Hopefully you guys can offer some advice as you have more experience than me with this type of stuff. Looking forward to feedback.
(PS: budget is probably $1,600 at most)
