Solved
Boot-start or system-start driver failed to load:dtsoftbus01
Last response: in Windows 7
May 21, 2011 7:26:27 AM
So ive been getting the black screen with movable cursor lately and have tried many a methods to remove it i tried checking in my event log for something, and this is waht it said "The following boot-start or system-start driver(s) failed to load:
dtsoftbus01" So what does this mean and how can i fix this?
Regards,
Best solution
May 21, 2011 2:31:49 PM
Found this if you want to give it a try:
"You need to disable driver verifier in your system.
Open Start menu -> Run... -> type verifier.exe and press Enter.
Then select "Delete existing settings" and click Finish.
Reboot your system and check the problem."
May 23, 2011 8:39:05 AM
Best answer selected by aneeb.
m
l
May 23, 2011 8:39:16 AM
thank you it seems to work :D
m
l
February 14, 2012 1:56:01 PM
Thank you guys! I was just about to re-install my Windows 7 Pro 64-bit.
You saved me!
m
l
