Tom's Hardware > Forum > Computer Peripherals > Printers > Need Help with NEC SuperScript 870 Laser Printer
Forum Computer Peripherals : Printers - Need Help with NEC SuperScript 870 Laser Printer
Archived from groups: comp.periphs.printers (More info?)
My NEC SuperScript 870 Printer has developed a small problem with an
image dropout along the left side of the printed page. It is slight
but noticeable.
It is not a sign of low toner, as the toner cartridge was recently
replaced. Before I have to spend the money on a new photoconductor
cartridge, I'd like to try cleaning or other diagnosis of the problem.
Are there any experts here?
Other than pulling out the toner cartridge and photoconductor
cartridge, what else can I do to examine and/or clean the unit? Do
those printer cleaning sheets made by Kensington do any good?
Many thanks for any help you're able to offer.
- Earl
Sponsored Links
In message <1121695211.623130.234930@z14g2000cwz.googlegroups.com>,
earlsjones@gmail.com writes
>but noticeable.
Is it a two part printer? Does it have toner and developer?
Other things that might want cleaning: Does it have a laser lens cover
that can be removed and cleaned? Are there wires (the phrase corona
wires sounds right) that can be cleaned, maybe by the machine itself?
Does it have a menu which covers some cleaning options?
Timothy
Reply to ME
"me@privacy.net" <me@Privacy.Net> wrote in message
news:natXxOH$ZR3CFw+f@town-village.demon.co.uk...
> >but noticeable.
> Timothy
Timothy -
The two replaceable parts are the toner cartridge and the photoconductor
cartridge (the "drum" ). I had a TI Microlaser many years ago that had a
replaceable developer cartridge also, but this printer is not like that.
What I would like is some specific advice on cleaning, and what to look for.
Thanks.
Reply to Anonymous
I apologize if these seem obvious.
Have you made sure the toner is distributed properly within the
cartridge by rocking it back and forth?
If you se an exposed corona wires, or if the cartridge has internal ones
which are accessible via a trap door and there is a tool provided, use
it to make sure these are not coated in toner.
If you see a window that the laser "shoots" through within the printer,
make sure it is clean.
Art
> but noticeable.
> - Earl
Reply to Anonymous
There are 1136 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
