I just put together a Core 2 Duo System... started it up, but nothing happened. The computer fans are all running at the highest velocity possible and all led case lights are on. Nothing shows up on my monitor, just stays in stand-by mode. I have looked at all wires, and everything seems okay. I have switched monitors but that hasn't made any difference. Any ideas?
I have heard that Core 2 Duo's are not compatible with the P5W DH motherboard until after a bios update (however, they are able to run on the older bios, but not up to their highest performance)
Any ideas on what I can try to do?
