I need advice on overclocking this system:
AM2 AThlon X2 3800
Gigabyte GA-M59SLI-S5
Patriot DDR2 - 800 1 gig cas. 4
7900 GT
600 watt PSU
blah blah blah...
First Question:
Should I use EasyTune5?
It only allows me to change FSB, CPU voltage, Multiplier, memory Freq, mem voltage...this doesnt seem like all the settings im going to need to tweak...
Second Question:
When tweaking in the BIOS under the M.I.T. catagory I can not find where to modify the HT. I can only modify the CPU HT - Link Voltage and HT-Link Voltage... they are two seperate things. Whats wrong here"
Third Question:
I want to take my 3800 X2 from 2.0 to 2.4 ghz and here are the settings I am trying to use:
CPU Freq : 240
Multiplier ratio : 10
CPU Voltage: 1.5
What else do I need to change? Will I have to clock down my DDR2? If so.. to what? Right now I plan on staying at 2.1 - 2.2 ghz and wait to take it to 2.4 until I get more advice from you guys. Thanks a lot guys!
AM2 AThlon X2 3800
7900 GT
600 watt PSU
blah blah blah...
First Question:
Second Question:
Third Question:
CPU Freq : 240
CPU Voltage: 1.5
