I just built my first computer using an ASUS P5W DH MB, an Intel E6600, a BFG 7900GTX video card, 2 GB of OCZ DDR2 800 memory and a 300 gigabyte Seagate SATA 2 hard drive.
I built it and it started up just fine. I installed Windows XP Pro using the disc from my old Gateway and got a few error messges about not being able to install some files. I told the install program to just continue and everything seems to run fine, but I cannot connect to the internet.
The MB has two LAN connections on it and I set everything up according to a tech from Comcast who said everything was set correctly, but the computer still lists the connection as being plugged in, but no connectivity.
Any suggestions as to what I might have screwed up or is it possible that Gateway had some proprietary files on the disc that prevent it from installing correctly on any other computer?
I was trying to save a little money considering the cost of buying a new Windows XP.
Any help would be greatly appreciated!
