I have never built a computer before. However, recently I decided that I was going to build myself one. It will be for gaming and all-around use. I plan to upgrade the computer as soon as I get the money, because funds are currently limited. I would like any advice on these components.
Case:
APEVIA (ASPIRE) X-CRUISER-RD Red Steel ATX Mid Tower Computer Case
I'm not sure about the red, but I like the case.
PSU:
FSP Group (Fortron Source) FX600-GLN ATX12V/ EPS12V 600W Quad. SLi Power Supply
Seems ok. I'll want SLI later. Does this PSU only work with 7800s and 7900s?
CPU Cooling:
ZALMAN CNPS9500 AT 2 Ball CPU Cooling Fan/Heatsink
Good reviews, and I'll want to overclock.
Motherboard:
MSI 975X Platinum Socket T (LGA 775) Intel 975X ATX Intel Motherboard
No idea if this is good or bad.
Processor:
Intel Core 2 Duo E6300 Conroe 1066MHz FSB 2M shared L2 Cache LGA 775 Processor
I like dual-core and these are supposed to be great for OCing.
RAM:
OCZ 1GB (2 x 512MB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800 (PC2 6400) Dual Channel Kit System Memory
Seems fine. I'll upgrade to 3gb soon.
I have a cheap Maxtor 40gb HDD and a 200gb external to last me for a while.
I already own an old 6800GS video card, so I'll get SLI later.
I have an old monitor to use until I can get a 19" widescreen LCD.
I have an old Dell mouse and keyboard and DVD drive.
I can get Windows easy.
So does that cover everything? Am I making any stupid mistakes? Any suggestions at all are welcome.
Case:
PSU:
CPU Cooling:
Motherboard:
Processor:
RAM:
