News
Creative Finally Launches True X-Fi PCI Express Parts
Published on May 19, 2008
  It took some time, but Creative Labs has finally introduced decent sound cards for PCI Express interface. Read more
Sound blaster cleans contaminated soil
Published on September 07, 2006
Soil polluted by organic toxins can be blasted clean with ultrasound, say researchers in Australia. The method may prove to be more effective at cleaning up contamination from oil refineries, power stations and aluminium factories than existing methods. Read more
CES 2007: A floating iPod sound system for your swimming pool
Published on January 03, 2007
Pre CES 2007 coverage - Atlantic has a new idea how to make an iPod more useful in the outdoor world. Read more
OCZ announces PC-4800 EL DDR Platinum Limited Edition
Published on March 02, 2005
OCZ announced a new high-performance DDR600 memory module. Read more
Latest Reviews & Articles
System Builder Marathon: Performance & Value
Published on October 31, 2008
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
System Builder Marathon: $500 Gaming PC
Published on October 30, 2008
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
Tom's SBM: The $1,500 Mainstream PC
Published on October 29, 2008
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
System Builder Marathon: The $4,500 Super PC
Published on October 28, 2008
This month's System Builder Marathon spreads the system prices out even further to $4,500, $1,500, and $500. Is today’s $4,500 system really worth three times as much as an upper-mainstream performance machine? Read more
  Tom's Hardware Forums » CPU & Components » Sound Cards » Sound Blaster Audigy 4 or Sound Blaster X-fi Platinum
Word :   Username :
Bottom
Author
 Thread : Sound Blaster Audigy 4 or Sound Blaster X-fi Platinum
Profile: newbie
More Information
I'm buying a new sound card and I really can't see much difference when comparing these 2 cards except that the audigy is a little cheaper. Any recommendations? All opinions and help on deciding this will be appreciated.
Related Product
The Order Odonata - We do what we must
Profile: Faithful Poster
More Information
They're both very descent sound cards, if you need to save $$ get the Audigy 4...if you want the latest and greatest and all the toys that can be had (24bit Crystalizer, EAX 5, CMSS3D, breakout box)...get the X-Fi. If 2-channel stereo is all you're really going to use than the cards are pretty evenly matched and the X-Fi would be overkill given very similar performance can be had by a lot of less expensive audio boards, including, but not limited to, the Audigy 4. X-Fi Platinum? Why? Is that breakout box really worth $50-$80 to you? There's no other difference between the Platinum and Extreme Music versions. ...and you can get the Creative's digital I/O (Coax and Optical S/PDIF) for $15 if its digital I/O you seek.
Profile: newbie
More Information
Hi,
I found this thread quite interesting to me as well. I am thinking about buying either Audigy SE or audigy 4. Is there a noticeable differece in sound quality between these ? I will be mainly listening to stereo.
Regards,
Lukas.
Still playing my Dreamcast
Profile: Forum Veteran
More Information
Why are you even considering the two? Do you require other audio outputs that don't come with the X-FI Xtreme music? Guitar input? If not, get the X-FI Xtreme music; same audio quality as the X-FI Platinum for less.
More Information
Quote :
Hi,
Regards,
Lukas.
I'd go with the Chaintech AV-710 as it cost about the same as the Audigy SE and is a far better card, in terms of capability. ...but if you must have Creative, get the SE for mainly stereo.
Google Ads
