Hello all,
I ma going to be building a new system for a friend at work but they want a micro atx case the little cubes, now with that do I need a different cooling fan/hs for the cpu??
I ma looking at getting an Antec Aria MicroATX Cube Case. And the manual said something about a CPU cooling fan bracket that is optional but it looked like a fan that was just supported in mid air???
I will be putting in an athalon 64 3500+ socket 939 CPU and want to make sure I get the right hs if I need a smaller one or whatever I need to do...
THANKS!
Brycer79
THANKS!
Brycer79
