Hey guys, this is my first post, and I gotta Q!
Do you guys have any Suggestions on optimizing my system without overdooing it? (OC'ing is fun, but i'd rather optimize slightly than overclock). Butttt, also give OC'ing info if you have any, I want to get as much knowledge about what i can do to this as I can ^^
Any Drivers that I should get?
Also, I am thinking about getting a new fan for my CPU, I dont really like that it is sitting at 50C ATM without any overclocking and the stock fan, Anyone know any good AM2 socket fans that are still valid with AMD?
System Specs:
Asus MS2-SLI Deluxe Revision 0202
AMD Athlon(tm) 64 X2 Dual Core Processor 3800+ AM2 Socket
2x512MB DDR2 533 Dual Channel Ram
BFG Tech GeForce 7600 GT OC PCI Express x16
Western Digital 80GB Special Edition Serial ATA Drive
ThermalTake Thoughpower 600W PSU
CPU-Z Info: (cut down lol)
Processors Information
Number of cores 2
Number of threads 2 (max 2)
Name AMD Athlon 64 X2 3800+
Codename Windsor
Specification AMD Athlon(tm) 64 X2 Dual Core Processor 3800+
Package Socket AM2 (940)
CPUID F.B.2
Extended CPUID F.4B
Brand ID 4
Core Stepping BH-F2
Technology 90 nm
Core Speed 2007.2 MHz (10.0 x 200.7 MHz)
HT Link speed 1003.6 MHz
Stock frequency 2000 MHz
FID/VID Control yes
max FID 10.0x
VID range 1.125V - 1.350V
K8 Thermal sensor yes
K8 Revision ID 5.2
Temp. 50C
Chipset
Northbridge nVidia nForce 570 SLI rev. A1
Southbridge nVidia nForce 570 SLI rev. A2
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 1024 MBytes - PC2-4300 (266 MHz)
Memory Frequency 250.9 MHz (CPU/8)
CAS# 4.0
RAS# to CAS# 5
RAS# Precharge 5
Cycle Time (tRAS) 15
Bank Cycle Time (tRC) 17
Command Rate 1T
DMI BIOS
vendor Phoenix Technologies, LTD
version ASUS M2N-SLI DELUXE ACPI BIOS Revision 0202
date 05/15/2006
If you cared to read over it, I am thankful for just that, if you have any suggestions, I will smother you with thanks lol.
Thank you.
Soul
System Specs:
Number of cores 2
Codename Windsor
CPUID F.B.2
Extended CPUID F.4B
Brand ID 4
Core Stepping BH-F2
Technology 90 nm
FID/VID Control yes
max FID 10.0x
K8 Revision ID 5.2
Temp. 50C
Chipset
Memory Type DDR2
CAS# 4.0
RAS# to CAS# 5
RAS# Precharge 5
Command Rate 1T
DMI BIOS
date 05/15/2006
Thank you.
Soul
