Tom's Hardware > Forum > Windows 7 > Windows 7 General Discussion > DON'T want to use Aero - but a problem
Forum Windows 7 : Windows 7 General Discussion - DON'T want to use Aero - but a problem
I'm having a bit of graphical instability in the UI of the architectural design software we use at work. I thought perhaps using a non-Aero theme (no animations or transparency nonsense) would help. So I tried changing to a different "standard" theme, but then suddenly the contents of my left (primary) display had an "edge bleed" problem where the maximized window contents on that screen would bleed over about 10 pixels onto my right screen. These are both Dell Ultrasharp 19" 1280x1024 LCD displays.
Anyone else had this issue or have a remedy?
Sponsored Links
Have you tried updating your graphic drivers?
Reply to TheViper
Yep, yesterday I installed the latest driver released this past Tuesday.
Message edited by PatrickGSR94 on 11-14-2009 at 12:01:32 AM
------------------------------ Custom CAD Rig
Pentium D 940 3.2 GHz
2x 1GB DDR2 667 SDRAM
Reply to PatrickGSR94
press the autoajust button on your monitor to get it to reshape the image
so why disable aero? it works 100% and has been proven to be quicker in games when left on?
------------------------------ Q6600@3510/1560 + TT BigTyphoon+Mod
8gb Kingston 800mhz
Gigabyte EP35-DS3P
XFX 8800GT/512
Reply to apache_lives
Reset the refresh rate to something other than 60Hz; 70, 72, 75... It's under the Advanced>Monitor tab...
Message edited by marcellis22 on 11-14-2009 at 02:41:44 AM
Reply to marcellis22
See my post above. We use Autodesk Revit Architecture 2010 in our office, and the ribbon display (new in 2010, similar to Office '07+ ribbon) seems to have some graphical instability that wasn't there in XP Pro x86. Sometimes the ribbon will disappear, then reappear when I move my mouse over it. Someone on the Revit forums suggested disabling Aero, but then I get the "bleeding edge" problem I described.
Tried switching to 75 Hz refresh (only rate my displays support other than 60) but still the same issue.
Message edited by PatrickGSR94 on 11-16-2009 at 02:56:48 PM
There are 1272 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
