Hello, i bought a PSU from a second hand store for $5 and want to know if it will work in my computer. The one i bought is brand new in a different box. there is no dust inside at all and the power cables are still rubber banded togather just like new. I have a Compaq Presario s4220NX with a 250 Watt hipro dr2537f3r power supply in it. I have a MSI MS6390 ver 3 motherboard with the 20 pin connector and the other four pin one. The new supply has some voltages and stuff on it but not any brand name that i recognize. I got a model number off the card inside the psu. It's just like this inside on the circuit board: LP-8860 REV:0402 then under that is: LP/ATX8860/0402 then under that is a date: 2004-11-10
On the underside of the board is the model number again and then another set of numbers and letters: backwards R and a U stuck to the back of the R then CF in a circle then 0394V0 then a solid tringle the size of a V but upside down.
There is a sticker on the out side with voltages and the amps for each that are higher than mine of course because the sticker says it is a 450 watt.
I was wondering if it would be safe to use this supply instead of my old one as i put in a new video card and the watts are very close to 250 on my system right now. I have had problems with one game in particular, GRAW, and i think power might be an issue. If you know where i can go to find out if this is compatible with my system i would appreciate it.
