Thermaltake Bigwater 745 120mm x3 CPU Liquid Cooling Fan/Heatsink
http://www.newegg.com/Product/Product.asp?Item=N82E16835106074
When i save the money i'd like to try it. just because i've never done it before. And that unit seems pretty decent.
Questions:
Where do i put it? i know the block goes on the cpu. I mean the other stuff. Can i place that at the bottom of the case? Do i gotta cut holes on my case? which i'm not doing because its steal. I have a Antec SOHO server steal case.
THe fans - where do thse go?
Like think of me is a newborn with liquid cooling. =)
edit: nvm i found a nice graphic on thermal's site.
Does anyone have this? can i lose the 2 120mm fans and just use the one 120mm? I'd just wanna cool the cpu.
If one of the hoses were to break and leak all over the inside of the case, what should i expect to happen? (lol) is it rare for a leaky hose or is it common?
Questions:
