A new generation of aftermarket heat-pipe-equipped VGA coolers has entered the stage. Their mission? To take the heat off the fastest, hottest GPUs on the planet.
also if he thinks one stock cooler is bad try listening to 2 of them at startup. its like living next to an airport
nice review although i wouldn't mind knowing what ambient temp that room he was in was at.
my room may be cool but right now my x1900xt is sitting at 47C. even on hot days it usually sits at 50-52C.
I was surprised by the poor performance of the VF900; I've seen other reviews that speak very highly of it. However, it is the most quiet, and relatively affordable.
I also have a slot fan under that vga card. IT helps blow the air out of case, very effective in keeping your case cool.
one thing i wouldn't mind seeing is how the new style cooler as seen on the x1950xt would do. it looks slightly different than the stock 1900 one.
does anyone know how it does. i'm interested for no other reason than curiosity.
ye i heard due to it having less fins on the fan it is quieter but i think it also has a fully copper heatsink for the memory and has the fan blowing across the new memory.
obviuously when this review was done they probably couldn't get their hands on one. i am guessing this was the case as the cats used was 6.5's
is it just me or is that one missing a key component needed that the article title might hint at
StrangeStranger was referring to the Silenx cooler, which doesn't appear to use a heat pipe...Only one?
I used the hottest card I had. Isn't the X1900 XTX hotter than the 7900 GTX? Plus, the review is for coolers, not video cards... the only use the video card for is to provide a 'control' so that the data we gather from the coolers is standardized.No nvidia.
You answered your own complaint.No water (I know - title is heat pipe...)
Holy crap, that would have taken forever. I would have liked to have had the time to do that, but, a few degrees here or there isn't going to make a colossal difference in OC ability. More realistically, if I'd have had time I would have tested with the best and worst solution. Like I said, didn't have the time tho.No max OC data on each.
Please do! :twisted:I could go on.
the VF-900Cu with its heat pipes really shines when you OC and put the GPU under load.
No nvidia.
[Holy crap, that would have taken forever. I would have liked to have had the time to do that, but, a few degrees here or there isn't going to make a colossal difference in OC ability. More realistically, if I'd have had time I would have tested with the best and worst solution. Like I said, didn't have the time tho.
I could go on.
Surely you have a bundle of DX-10 cards you're previewing...
One thing I have piddled with is varying ambient temps then monitoring CPU and GPU temps. It's not a simple linear relationship and it does affect my CPU OC at the high end (30C ambient). So I'm thinking that inside exhaust actually can have an impact if you are already pushing the CPU or GPU OC hard. That's not a question or request, but I guess it would be interesting to see data (case temps, with and without door fan, inside vs. outside exhaust, etc.) I am data-centric and just like to see all relevent numbers.
