I've read thru several of the posts regarding RAID setup, etc but still have some questions. This is my 2nd build but I've never done RAID before.
Here's the basics of the system: AMD Athalon 64 X2, Asus Crosshair mobo with onboard RAID, Win XP Pro x64, 4 WD RE 250 GB HDs.
I'm gonna use the mobo onboard RAID controller to setup a RAID 5 array using the 3 WD HDs. There's nothing loaded yet. What is the order to setup the system for OS install, RAID config, etc?
Do I install Win XP first and then configure the RAID array, or vice versa?
The RAID array is configured in the BIOS -- right?
I want to partition the array into 3 logical drive letters. When is that done?
What else should I be thinking about?
I'd appreciate any help. Thanks.
