What does one long beep at post mean? This is at least twice as long as a regular post beep and the system will not start....
Is this a new build? Also give system specs.
Check your motherboard's manuel. It should give you a list of beep codes and there meaning.
My guess would be check your video card. Make sure it's seated correctly. Just to be safe double check all your connections inside the case.
Nice... glad you got it up and running!I cleared the CMOS and got it going....
