please help i really appreciate any comments or advice. i will mainly use the computer for burning/recording tv/web and some gaming. i am on a budget of say $730-$780 and want to build a fast, powerful, yet affordable system. well here is what i got so far:
cd/dvd burner: http://www.newegg.com/Product/Prod [...] 6827152058
some changes i was considering was the mobo. are there better ones with similar features at lower prices? sorry im new at this.
the processor...is it better getting a 4200 or stay with the 4600.
i keep hearing how am2 is the way to go and thats what i would like to go with unless im hearing wrong.
oh and as far as video cards i have an ati hdtv card and ati 9200se but was thinking of getting a video card later unless there is a good one out there that is not too pricey ($130 max). and maybe with sli? thanks guys
I'd say go for the 4200 and spend some more money on a newer video card or more RAM. I'd also suggest getting a 2x512MB setup so that your RAM can be dual-channel.
For the VC I'd suggest a GeForce 7300GT or 7600GS. Under $100 and should last you until DX10.
Motherboard: Asus M2N-E <--- There is no reason to go SLI, unless you're going to be gaming at resolutions of 1600 x 1200 or higher, or unless you want to use more than 2 monitors.
RAM: When buying ram, ALWAYS get 2 sticks for dual channel, better yet get a matched set for the best results in terms of stability..... this Corsair XMS2 set should do just fine.
