Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > I still don't understand my PC's problems :(
I spent like 6 hours talking to a TSR of SOE's and they cudnt help...
I get weird little blobs of colour around on some textures and on EQ2 the UI
I Exit the game and my screen keeps flashing black and then back to normal as if i was constantly reseting the Resolution. Just keeps doing it till i reset.
Nvidia geforce 7900gt gainward golden sample
core 2 duo 6700
They're the important specs with this problem...
2 screens of some problems:
http://img212.imageshack.us/img212 [...] pj9co8.jpg
http://img105.imageshack.us/img105 [...] ledxi2.jpg
Sponsored Links
List your system specs, is your card running hot?...do you overclock?...is your p.s. powerful enough?....is your 7900 one of the defective ones that were crapping out on everybody?
Reply to GeneticWeapon
I just ordered the parts about 2 weeks ago.
Heres my GPU:
http://www.gainward.net/products/p [...] ucts_id=49
I don't overclock
It's running at 51c in games
my PSU is a enermax 600watt
And yes my GPU is plugged into it correctly.
My dxdiag:
System Information
Time of this report: 9/2/2006, 15:16:39
Machine name: MONICA-A7568120
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp.050928-1517)
Language: English (Regional Setting: English)
System Manufacturer: GBT___
System Model: AWRDACPI
BIOS: Award Modular BIOS v6.00PG
Processor: Intel(R) Core(TM)2 CPU 6700 @ 2.66GHz (2 CPUs)
Memory: 1024MB RAM
Page File: 280MB used, 2179MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 7900 GT
Manufacturer: NVIDIA
Chip type: GeForce 7900 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0291&SUBSYS_080110B0&REV_A1
Display Memory: 512.0 MB
Current Mode: 1280 x 960 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.8421 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 3/9/2006 15:29:00, 3968512 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 3/9/2006 15:29:00, 3650368 bytes
Device Identifier: {D7B71E3E-41D1-11CF-E553-0B2800C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0291
SubSys ID: 0x080110B0
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_1458E601&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.5282 (English)
WHQL Logo'd: Yes
Date and Size: 7/24/2006 16:15:04, 4353024 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Description: Realtek HD Audio Input
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
Description: Realtek HD Digital input
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x2830
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 23:08:44, 57600 bytes
| Driver: usbd.sys, 8/4/2004 13:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/4/2004 13:00:00, 52736 bytes
| Driver: kbdclass.sys, 8/4/2004 13:00:00, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes
+ PS/2 Compatible Mouse
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: mouclass.sys, 8/4/2004 13:00:00, 23040 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 62.4 GB
Total Space: 70.9 GB
File System: NTFS
Model: WDC WD740GD-00NLR1
Drive: D:
Model: LITE-ON DVDRW LDW-411S
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/4/2004 13:00:00, 49536 bytes
System Devices
Name: Intel(R) P965/G965 PCI Express Root Port Device ID: PCI\VEN_8086&DEV_29A1&SUBSYS_00000000&REV_02\3&13C0B0C5&0&08
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 23:07:48, 68224 bytes
Name: Intel(R) P965/G965 Processor to I/O Controller Device ID: PCI\VEN_8086&DEV_29A0&SUBSYS_00000000&REV_02\3&13C0B0C5&0&00
Driver: n/a
Name: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_8086&DEV_284B&SUBSYS_A0021458&REV_02\3&13C0B0C5&0&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 1/7/2005 17:07:18, 138752 bytes
Name: Intel(R) ICH8 Family PCI Express Root Port 6 - 2849
Device ID: PCI\VEN_8086&DEV_2849&SUBSYS_00000000&REV_02\3&13C0B0C5&0&E5
Name: Intel(R) ICH8 Family PCI Express Root Port 5 - 2847
Device ID: PCI\VEN_8086&DEV_2847&SUBSYS_00000000&REV_02\3&13C0B0C5&0&E4
Name: Intel(R) ICH8 Family PCI Express Root Port 1 - 283F
Device ID: PCI\VEN_8086&DEV_283F&SUBSYS_00000000&REV_02\3&13C0B0C5&0&E0
Name: Intel(R) ICH8 Family SMBus Controller - 283E
Device ID: PCI\VEN_8086&DEV_283E&SUBSYS_50011458&REV_02\3&13C0B0C5&0&FB
Driver: n/a
Name: Intel(R) ICH8 Family USB2 Enhanced Host Controller - 283A
Device ID: PCI\VEN_8086&DEV_283A&SUBSYS_50061458&REV_02\3&13C0B0C5&0&D7
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 13:00:00, 7168 bytes
Name: Intel(R) ICH8 Family USB2 Enhanced Host Controller - 2836
Device ID: PCI\VEN_8086&DEV_2836&SUBSYS_50061458&REV_02\3&13C0B0C5&0&EF
Name: Intel(R) ICH8 Family USB Universal Host Controller - 2835
Device ID: PCI\VEN_8086&DEV_2835&SUBSYS_50041458&REV_02\3&13C0B0C5&0&D1
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 20480 bytes
Name: Intel(R) ICH8 Family USB Universal Host Controller - 2834
Device ID: PCI\VEN_8086&DEV_2834&SUBSYS_50041458&REV_02\3&13C0B0C5&0&D0
Name: Intel(R) ICH8 Family USB Universal Host Controller - 2832
Device ID: PCI\VEN_8086&DEV_2832&SUBSYS_50041458&REV_02\3&13C0B0C5&0&EA
Name: Intel(R) ICH8 Family USB Universal Host Controller - 2831
Device ID: PCI\VEN_8086&DEV_2831&SUBSYS_50041458&REV_02\3&13C0B0C5&0&E9
Name: Intel(R) ICH8 Family USB Universal Host Controller - 2830
Device ID: PCI\VEN_8086&DEV_2830&SUBSYS_50041458&REV_02\3&13C0B0C5&0&E8
Name: Intel(R) ICH8 2 port Serial ATA Storage Controller - 2825
Device ID: PCI\VEN_8086&DEV_2825&SUBSYS_B0021458&REV_02\3&13C0B0C5&0&FD
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 13:51:52, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:44, 95360 bytes
Name: Intel(R) ICH8 4 port Serial ATA Storage Controller - 2820
Device ID: PCI\VEN_8086&DEV_2820&SUBSYS_B0021458&REV_02\3&13C0B0C5&0&FA
Name: Intel(R) ICH8/ICH8R Family LPC Interface Controller - 2810
Device ID: PCI\VEN_8086&DEV_2810&SUBSYS_00000000&REV_02\3&13C0B0C5&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/17/2001 13:58:02, 35840 bytes
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_F2\3&13C0B0C5&0&F0
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_197B&DEV_2363&SUBSYS_B0001458&REV_02\4&23995DF6&0&00E5
Name: Marvell Yukon 88E8053 PCI-E Gigabit Ethernet Controller
Device ID: PCI\VEN_11AB&DEV_4362&SUBSYS_E0001458&REV_22\4&19FEE395&0&00E4
Driver: n/a
Name: NVIDIA GeForce 7900 GT
Device ID: PCI\VEN_10DE&DEV_0291&SUBSYS_080110B0&REV_A1\4&2CCDD017&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0010.8421 (English), 3/9/2006 15:29:00, 3650368 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0010.8421 (English), 3/9/2006 15:29:00, 3968512 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0010.8421 (English), 3/9/2006 15:29:00, 143436 bytes
Driver: C:\WINDOWS\system32\nvhwvid.dll, 6.14.0010.8421 (), 3/9/2006 15:29:00, 573440 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0010.8421 (), 3/9/2006 15:29:00, 98304 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0010.8421 (English), 3/9/2006 15:29:00, 5419008 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0010.8421 (English), 3/9/2006 15:29:00, 7561216 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0010.8421 (English), 3/9/2006 15:29:00, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0010.8421 (English), 3/9/2006 15:29:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11026 (English), 3/9/2006 15:29:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0010.8421 (English), 3/9/2006 15:29:00, 229376 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 3/9/2006 15:29:00, 171072 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 3/9/2006 15:29:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 3/9/2006 15:29:00, 35840 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 3/9/2006 15:29:00, 35840 bytes
Name: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_104C&DEV_8024&SUBSYS_10001458&REV_00\4&20E0FF6A&0&30F0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/4/2004 13:00:00, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/4/2004 13:00:00, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/4/2004 13:00:00, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/4/2004 13:00:00, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 14:46:40, 6400 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/4/2004 13:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/4/2004 13:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/4/2004 13:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 13:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/4/2004 13:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/4/2004 13:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/4/2004 13:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/4/2004 13:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/4/2004 13:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/4/2004 13:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 13:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/4/2004 13:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 35328 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 82432 bytes
system.dll: 1.01.4322.2032 English Final Retail 8/28/2006 13:57:48 1224704 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/4/2004 13:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 13:00:00 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 13:00:00 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 13:00:00 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 13:00:00 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/4/2004 13:00:00 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 13:00:00 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 13:00:00 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 13:00:00 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 20480 bytes
qasf.dll: 10.00.0000.3802 English Final Retail 1/28/2005 13:44:28 221184 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 13:00:00 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 13:00:00 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 13:00:00 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 13:00:00 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 13:00:00 733696 bytes
quartz.dll: 6.05.2600.2749 English Final Retail 8/30/2005 04:54:26 1287168 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/4/2004 13:00:00 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 13:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 13:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 13:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 13:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 13:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 13:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 13:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 13:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 13:00:00 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 22:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 13:00:00 118272 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 13:00:00 1428480 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 17408 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 13:00:00 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,6.02.0005.0034
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3802
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3646
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
CyberLink AudioCD Filter (PDVD6),0x00600000,0,1,CLAudioCD.ax,5.00.0000.3114
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
CyberLink Audio Decoder,0x00602000,1,1,CLAud.ax,6.00.0000.2001
AC3Filter (Dr.DivX),0x00400000,1,1,AKE007.ddc,0.07.0000.0000
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
CyberLink Audio Effect (PDVD6),0x00200000,1,1,claudfx.ax,6.00.0000.1223
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3646
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2749
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
CyberLink Demux (PDVD6),0x00400000,1,0,cldemuxer.ax,1.00.0000.2905
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CyberLink Line21 Decoder (PDVD6),0x00200000,0,2,CLLine21.ax,4.00.0000.4520
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3646
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
CyberLink Audio Spectrum Analyzer (PDVD6),0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.02.0005.0034
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3802
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
DivX Demux,0x00600000,1,0,DivXMedia.ax,0.00.0000.0028
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
CyberLink Video/SP Decoder,0x00602000,2,3,CLVsd.ax,6.00.0001.1921
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
CyberLink DVD Navigator (PDVD6),0x00600000,0,3,CLNavX.ax,6.00.0000.2017
CyberLink TimeStretch Filter (PDVD6),0x00200000,1,1,clauts.ax,1.00.0000.2212
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
Cyberlink SubTitle Importor (PDVD6),0x00200000,1,1,CLSubTitle.ax,1.00.0000.1604
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
.RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
DivX Subtitle Decoder,0x00600000,1,1,DivXMedia.ax,0.00.0000.0028
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 6.2.5 Codec (2 Logical CPUs),0x00200000,1,1,qcap.dll,6.05.2600.2180
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 6.2.5 YV12 Decoder,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2749
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
MSN Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
Audio Capture Sources:
Realtek HD Audio Input,0x00200000,0,0,qcap.dll,6.05.2600.2180
Realtek HD Digital input,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming Capture Devices:
Realtek HD Digital input,0x00200000,1,1,,5.03.2600.2180
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,2,1,,5.03.2600.2180
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.2749
CyberLink Audio Renderer (PDVD6),0x00200000,1,0,cladr.ax,6.00.0000.1817
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming System Devices:
Realtek HD Audio Input,0x00200000,4,1,,5.03.2600.2180
Realtek HD Audio output,0x00200000,18,1,,5.03.2600.2180
Reply to scaramoosh
wow. did we really need all that?
sounds like a duff card. send it back. get them to test it.
Reply to dougie_boy
Didn't we already go thru this on this topic?
Quote :
EQ2 TSR said its because these games dont support dual cores, so you have to disable one of the cores
Reply to hawkeye22
Yes but then it started doing it again :(
Reply to scaramoosh
There are 1285 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
