I have Sennheiser HD-595 and i use my comp mostly for playing CDs and DVD concerts.I plan use sond card only with headphones.
In games i'm happy with AC'97.
I've red what E-mu 1212m is good for music.
What do you think ?
I have the same headphones that you're using. I've heard that the E-mu card is good for pro-applications. For music? Well, I have an X-Fi and SB Live! ...both sound good for music and drive the headphones pretty well. I'd say, in your price range, look into these, they're all good cards (though most offer more than the 2-channel stereo you indicated to be your primary use, spelled "growth potential":
Likely not a complete list and you don't need to spend $220 on a soundcard to get high-performance (try not to be influenced by Creative's marketing too much), all of the above cards will do more than justice to the HD595's and many other audio requirements you may develop.
Not sure I would recommend anything from Auzentech for a user wanting to listen to music using headphones.
Auzentech cards are VERY good at handling Digital Audio (Encoding Dolby Digital Live! and in the case of the Xplosion DTS as well). But his headphones are analog. And the analog sound coming out of my Auzentech Xplosion is reminiscent of on-board audio (AC'97).
For analog audio Creative's X-Fi are the best, especially when using headphones. Hellz even the Xtrememusic is more then adequate.
That's good to know that analog out from the Auzentech is comparatively weak. It looks like they took nearly the opposite approach than that of Creative...all-digital with weak analog as opposed to Creative's all-analog with weak digital.
That's why I run them both..
Auzentech Xplosion and Creative X-Fi.
Effective, but not for those of the weak-wallet. Did you have do any troubleshooting to get them to play nice together? With that setup you've all the options available to you, but for those that may have a little less to spend wouldn't a Montego DDL do the trick, and if anything, mate it to an Audigy 4, for a roughly $160 solution? I've not toyed with 2 cards from different manufacturers but running a setup like yours may, indeed, be the best of all worlds for the enthused. ...overkill for the OP's needs, but great for gaming and music.
Both the X-Fi and the XPlosion work well together. The only downside is if Physics cards catch on I'm out of PCI slots..lol
The Montego DDL is a nice card. But even then it's mean't to be mainly used for Dolby Digital Live! applications.
Xtreme Music. It costs significantly less and is the same audio card as the Platinum.
If the breakout box with the digital I/O, headphone output, etc. is REALLY important to you, only then would I recommend the Platinum. ...but I truly believe ~$50+ is too much to pay for the ROI.
