Right click on a folder...properties...nothing happens!!
Archived from groups: microsoft.public.win2000.file_system (More info?)
Please help, I right click on a folder ,in windows explorer, and choose
properties...nothing happens? Is it any fixes for this ? or do I have to do
I have to reinstall the system?
/MattiasG
4 answers Last reply
More about right click folder properties nothing happens
  1. Archived from groups: microsoft.public.win2000.file_system (More info?)
    Looks like you and I have the same problem, but nobody out
    there knows a solution, or they're not telling us
    John
    >-----Original Message-----
    or do I have to do
    >/MattiasG
  2. Archived from groups: microsoft.public.win2000.file_system (More info?)
    Are you by any chance using Zone Alarm? If so see here:
    Tip #437: Folder Properties Work-around when using ZoneAlarm
    http://windows.about.com/library/tips/bltip437.htm
    John
    > John
    > or do I have to do
    >>/MattiasG
  3. Archived from groups: microsoft.public.win2000.file_system (More info?)
    There are many possible problems leading to that, here's a possible
    solution found through google groups:-
    The "SYSTEM" account may not have full access privileges to everything
    on the
    drive. You may have to use cacls from a command prompt to mend it. Read
    the help
    for cacls very, very carefully. Take particular note that you should use
    the /E
    switch. You can /really/ mess up with cacls.
    Your computer may have a different problem, but the above fixed mine.
    Another potential problem is third-party context-menu items.
    Andrew
  4. Archived from groups: microsoft.public.win2000.file_system (More info?)
    MattiasG wrote:
    > *Please help, I right click on a folder ,in windows explorer, and
    > choose
    > to do
    > /MattiasG *
    I've encountered this bizarre inaction a few times. After hours spent
    trawling around fruitlessly, it seems to be related to ZoneAlarm (or
    poss other FW) and IIS. The problem went away when I did RESETIIS in a
    dos box. Someone has speculated that the properties command is doing an
    RPC call to IIS which is being blocked by ZoneAlarm. All very obvious
    really (not)...
    jastewart
    Posted via http://www.webservertalk.com
    View this thread: http://www.webservertalk.com/message469141.html
Windows Explorer File System Microsoft Windows
