Archived from groups: comp.dcom.lans.ethernet (More info?)
Hello group/list,
I've checked the FAQ but I couldn't find any reference to this issue.
Our campus LAN is mostly Gigabit Ethernet fiber and 100 Mb/s UTP
distribution, but we still have some distribution done to remote parts
of the campus done over LRE (long range Ethernet), which is much like a
"local DSL". It's supposed to give 10Mb/s under the best conditions
AFAIK.
People from these remote locations complain that traffic to servers on
the core network is very slow. I've ruled out problems at client or
server side. I've tested file transfers across the LRE segment and
across the Gb Eth. segment. Their speeds were close to the expected
max, so this (I guess) rules out problems on the segments themselves
(esp. the LRE). I'm starting to wonder whether the big drop in speed
between the two segments isn't the root cause (I mean, a 1Gb/s and a
10Mb/s segment). Would Ethernet gurus be so kind to comment? (I'm a
poor system admin, acting as a network admin!).
> to servers on the core network is very slow.
Gee ... people complain?
> I've ruled out problems at client or server side. I've
> tested file transfers across the LRE segment and across the
> Gb Eth. segment. Their speeds were close to the expected max,
Both directions? When users were complaining? I typically
run ttcp and ping
> I'm starting to wonder whether the big drop in speed between
> 10Mb/s segment).
AFAIK, ethernet itself isn't the issue, but that Crisco bridge
may be. TCP/IP has a discovery mechanism that can work well,
but hasn't always been well implemented (especially MS-Win9*).
I also believe some of the newer p2p apps use UDP. You may need
to sniff the link.
It gets into Quality-of-Service issues, but if someone is hogging
that 10 Mb/s line, everyone else will suffer. Paradoxically
worse (latency) if the Crisco or LRE has big buffers.
There is no issue with the speed mis-match that you describe.
TCP was designed to operate in that environment and as
is witnessed by the internet and other WANs does actually
does so.
Performance problems are always tricky, if you don't know
quite a lot about how this stuff works and can use tools
like packet sniffers and interpret the results it could be
quite difficult.
1.
The absolute first thing is to check the counters on all
of the equipment to see of there are errors accumulating.
Fix them. Any on Ethernet will most likely be caused by
duplex mis-match.
The error rate is basically zero on this kit now and
less than 1 in a million is OK. TCP is very good at recovery
and can hide much higher rates. On LANs most ports
have zero errors *ever*.
2.
Make sure that the performance is not actually as designed.
This is much harder. For example some users may complain
that windows file copies are very slow when they drag a directory
across the link. It casn take many net transactions to get even
one file across so the performance degrades quite quickly with
hops and or other latency and or slow links.
Eg to copy a file windows might do:
I made the details up but it is pretty close (I think).
Hello is filex there - wait on reply
Hello are you still there - wait on reply
Open file - wait on reply
Close file - wait on reply
Read first block - wait on reply
there was only one block so:
Close file - wait on reply.
Thats 7 transactions just to copy one tiny file.
Windows also keeps its explorer widow up to date
so that can be another load of transfers.
You can see this with a sniffer^h^h^h^h^h^h^h Ethereal.
> that 10 Mb/s line, everyone else will suffer. Paradoxically worse
Of course, if the buffers are too small - say smaller than they
typical TCP windows being used, a burst of traffic from the fast side
may fill the buffers and overflow. Checks of the statistics might be
in order - both netstat on the end systems and link-level on each side
of that 10 Mbit/s pipe (or anywhere there is a speed change I
suppose).
rick jones
The computing industry isn't as much a game of "Follow The Leader" as
it is one of "Ring Around the Rosy" or perhaps "Duck Duck Goose."
- Rick Jones
these opinions are mine, all mine; HP might not want them anyway... feel free to post, OR email to raj in cup.hp.com but NOT BOTH...
Thanks to you Robert, FAB, Rick for all the input.
I'll do another pass of investigation based on your comments, but here
are a few more words on this, though:
- duplex mismatch: I've checked this all along the path, no duplex
mismatch (esp. the UTP link between the SMC and the Cisco LRE switch)
- this problem seem to happen all the time. When I've done my tests,
I've used ftp transfers (from Unix boxes, so that I know at least that
the ftp server is decent). Yes, the slowness was in both directions,
although, as expected, download was always signficantly faster than
upload.
Ping times were normal. I'll try ttcp too, thanks.
- I've concentrated on one complaint from one user who's making ftp
transfers only... we don't allow P2P on the University campus anyway
- the LRE links are not shared, so no one can be hogging them
My guts feeling is that somehow data gets pushed too fast over the fast
link and that either of the SMC or Cisco LRE switches drop frames. I
understand that normal TCP window mechanisms should take care of that,
but I suspect that they
don't, somehow, and I'm not sure how to check this (where can I find
something about this in netstat output BTW?).
Any new hint is welcome, I'll followup after a new round of checking
counters and such.
> no duplex mismatch (esp. the UTP link between the SMC and
Also check cable termination quality. A split pair (homemade)
on a cable will ruin performance on that collision domain.
> done my tests, I've used ftp transfers (from Unix boxes,
> so that I know at least that the ftp server is decent). Yes,
> the slowness was in both directions, although, as expected,
> download was always signficantly faster than upload.
Is LRE assymmetric? I wouldn't expect different performances,
unless there are slow disks limiting.
> making ftp transfers only... we don't allow P2P on the
> University campus anyway :-)
If it's low ftp throughput, you might try adjusting that
users TCPRecvWindow.
> I understand that normal TCP window mechanisms should take care of
> that, but I suspect that they don't, somehow, and I'm not sure how
> to check this (where can I find something about this in netstat
> output BTW?).
On the sending side, look for lines relating to retransmissions.
Compar with total data segments sent. Also compare retransmissions to
data segments retransmitted. On the recv side, look for out-of-order
segments. While it may not match your platform entirely, the following:
on your system so you can "subtract" one netstat from the other (check
it carefully though, as that code was written and tested only on HP-UX
netstat and lanadmin - it is simple, but perhaps not simple enough)
TCP has mechanisms to attempt to adapt to congestion. How well it
works depends on the nature of the congestion and the flavor of TCP
being used - seems one sure way to get one's degree these days is
describe yet another tweak to congestion control
Someone else asked about asymmetry - that could indeed be an issue
particularly if the receiver is an "ack-every-other" and the asymmetry
is great - basically, if the ratio is worse than 2*MSS/60 where MSS is
the MSS for TCP over the asymmetric link and 60 is a wag for the size
of an ACK segment, then the ACK's may be saturationg the slow return
link and limiting the floy of TCP segments the other way.
rick jones
denial, anger, bargaining, depression, acceptance, rebirth...
where do you want to be today?
