Tom's Hardware > Forum > Smartphones & PDAs > Windows Mobile > accuracy of built-in battery meter on IPaqs? (2215)
Forum Smartphones & PDAs : Windows Mobile - accuracy of built-in battery meter on IPaqs? (2215)
Archived from groups: microsoft.public.pocketpc (More info?)
Does anyone have any information about how accurate the built-in battery
meter is on the IPaq series, especially the 2215? I'm interested in any
information on the reliability of the meter for either/both the regular
(removable) battery or the internal emergency battery.
If the battery meters aren't accurate, are there any utilities out there
that are more accurate? (vs a hardware issue, in which case any software
utility would be dealing with GIGO). Preferably something cheap or free, as
I only need to diagnose whether my unit is providing accurate information
maybe once or twice (at which point I may have to buy a new battery).
Thanks!
Keith
The enclosed questions or comments are entirely mine and don't represent the
thoughts, views, or policy of my employer. Any errors or omissions are my
own.
Sponsored Links
"KR" <nospam@nospam.com> wrote in message
news:uVPrPv$9EHA.3592@TK2MSFTNGP09.phx.gbl...
> as
> Thanks!
> Keith
I don't think the 2215 runs 2003, so this may not work. If you go to
settings\power\standby you can (on 2003 at least) see approx. hours left as
a number down to 1/10 hour. The cool thing about this is that you can
toggle wifi, backlight, bluetooth, etc. and see the numbers change
immediately. This may give you more feedback as you test your battery than
the standard gauge.
Then again, you may have already checked this and determined that you do not
trust the operating system (and utilities shipped with it) reporting the
values, in which case disregard this particular response.
Reply to Anonymous
The 2210 runs WM2003, it is the pre WM2003SE edition.
Darren Griffin
PocketGPSWorld - www.pocketgpsworld.com
The Premier GPS Resource for News, Reviews and Forums
Reply to Anonymous
It's extremely accurate, as all are if working as designed.
KR [Tue, 11 Jan 2005 11:37:12 -0500]:
40th Floor - Software @ http://40th.com/
iPlay : the ultimate audio player for iPAQs
mp3, ogg, mp4, m4a, aac, wav, play & record
parametric eq, xfeed, reverb - all on a ppc
Reply to Anonymous
The h2215 runs WM2003 (not Second Edition).
Darius Wey
Pocket PC Thoughts
http://www.pocketpcthoughts.com/
Reply to Anonymous
Er...ignore that message. I didn't see Darren's reply. ;-)
Darius Wey
Pocket PC Thoughts
Reply to Anonymous
Generally, it's quite accurate and does not suffer from the same
problems you might encounter on a laptop. You'll find that most meters
work on two levels: stastically estimated values of battery life, and
fixed values of battery life. Generally, the difference between the two
is not profound, especially on a Pocket PC. In a nutshell, rest assured
that the readback values you get in the default meters of your h2215 are
quite close to the real value.
Darius Wey
Pocket PC Thoughts
Reply to Anonymous
Reply to message from Darius Wey <darius.nospam@pocketpcthoughts.com> (Wed,
12 Jan 2005 00:29:16) about ""Re: accuracy of built-in battery meter on
IPaqs? (2215)"":
DW> Er...ignore that message. I didn't see Darren's reply. ;-)
Coolness. And thanks for the info - so many models, so little time. :)
Reply to Anonymous
There are 1093 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
