Help buying a card 150$ range agp
So im finally retiring my geforce ti 4400, and im wondering which card to go with in this 130 - 160 range. Here are a few ive narrowed, but Im willing to listen to advice on something completely diferent. Ive been looking for comparisin charts, but I never see detail on the GS or extreme cards.
Price $139 (after 30$rebate)
BFG Tech BFGR68256GSOC Geforce 6800GS 256MB 256-bit GDDR3 AGP 4X/8X
Price $128
XFX PVT42KVDE3 Geforce 6800XT 256MB 128-bit GDDR3 AGP 4X/8X
Price $149
BFG Tech BFGR76512GSOC Geforce 7600GS 512MB GDDR2 AGP 4X/8X
5 answers Last reply
More about help buying card range
  1. I have an x800 gto in my agp system and it works great. I payed $175 for it this spring and it's down to about $125. It's an awsome card. You could get an x800xt which is the next step up from the x800gto. But the Gto is fine. I was able to unlock the extra 4 pipelines and overclock it a little bit.
    Otherwise, I would say go for a 6600gt or a 7800gs. Yeah the 7800gs is expensive, but it is the best and last agp card ever designed.
    So take your pick.
  2. Leadtek A7600GT
    It performs better than all the cards you mentioned, but it's out of stock right now. If you don't want to wait for it to come back in stock, the 6800GS is your best bet.
  3. Another option will be the X1650 pro AGP - faster then the 7600GS (although not up to the 7600GT)
    http://www.diamondmm.com/X1650AGP256.php
    But it will be priced the same as the outgoing X1600 pro AGP, so good value. See below for a bench of it trashing the 7600GS... In shops in under 2 weeks, can you wait?
    http://www.elitebastards.com/cms/index.php?option=com_content&task=view&id=107&Itemid=27&limit=1&limitstart=2
  4. So the 6800GS is better then the extreme? That might be the one I go with then, because that price is perfect for me. The 7600 you mentioned I could probably do money wise.....but is it that noticible of a diference then the 6800GS?
    If its enough of a diference I wouldnt mind paying out another 40$ for something I would be happier with, and be able to stay with longer.
    thanks for the replys guys :)
    on the ati thing Ive owned 2 ati cards in my life, and neither time I was that happy with. It was a long time ago when they always had issues with drivers, which I dont believe is a problem anymore......so changing back over to ati isnt out of the question.....Ill take a look at the 2 cards you recommended.
    thanks!
  5. Hey guys I have the same question.
    Which is better? The leadtek 7600 GS or the BFG 6800 GS?
    The 6800 GS has 256 Bit Lane so wouldn't that make it better than leadteks? Can someone confirm please.
    ~Defender~
Nvidia Geforce Graphics Product
