Tom's Hardware > Forum > Computer Peripherals > Printers > Canon pixma ip5000 problem
Forum Computer Peripherals : Printers - Canon pixma ip5000 problem
Archived from groups: comp.periphs.printers (More info?)
I wonder if some kind person can throw some light on a problem that has
developed on my 6 month old printer.
Basically the print out became muddy and when I ran a nozzle check it
showed that the yellow ink was almost grey (the printer has separate
cartridges and the yellow tank is adjacent to the larger of the black
tanks)
the problem disappeared with a nozzle clean but over a short time even
when the printer was sitting idle the yellow turned grey again. I have
changed both yellow and black tanks (compatible cartridges) to no avail.
I wonder if anyone can advise me whether this could be a problem with
the printer rather than the ink tanks or if there is some way I can cure
it.
Many thanks
Mary
Mary Haggie
Sponsored Links
>tanks)
>it.
>Many thanks
>Mary
>Mary Haggie
Mary
Sounds like there is cross colour at the printhead. Suggest you get it repaired
under warranty, some warranty service people may be loath to touch it if there
are non-OEM ink cartridges in the printer so be warned. (Please no OEM versus
non-OEM debates from any lurking zealot, non-OEM ink cannot cause cross colour
at the head!!!).
Good luck
Tony
Reply to Tony
> tanks)
The advice you got on steve's fourms if pretty sound... contact canon.
I haven't had canons long enought to be great at trouble shooting but
the following seems likely
*1. Bad seals between the ink-tank and the printhead assembly. Either
replace the seals if it's possible or get a new printhead. Should be
under warranty
2. Bad ink-tank, the port to the head has a flaw and is bleeding over
to the other tanks. resolustion replace your ink, try a different
brand... ask over at
http://www.nifty-stuff.com/forum/viewforum.php?id=12 about particulars
also might wish to ask the people who you bought the ink from... this
could be a symptom others experenced and might have a resoltuion...
probally returning what you bought in favor of something new.
3. Leaky tanks that dripped a small amount of black ink ink "near" the
yellow intake port Resolution... remove and clean with index.
Reply to zakezuke
In article <1124078200.118184.122030@g43g2000cwa.googlegroups.com>,
zakezuke <zakezuke_us@yahoo.com> writes
>> tanks)
>under warranty
Thank you both, this morning I rang Canon and it seems they accept it is
a printhead problem, so I have to email off my receipt etc to them and
they will send me a new printhead.
(I've done dozens and dozens of cleaning cycles over the past week or
so, at least having had compatible cartridges in has been a lot cheaper
on ink than if I'd had the originals!)
I checked on the cost of the large black Canon original ink cartridge
this morning in PCWorld, it was GBP 10.99, whereas the printrite one is
less than GBP2, this does not encourage one to buy originals I'm afraid
for general printing jobs.
(I remembered Steve's forums from about 4 years ago when I was looking
for info before buying my digital camera, a great resource for printer
info also!)
Thanks again for all the useful information, I did email the ink
supplier but have heard nothing back yet.
best wishes
Mary
Mary Haggie
Reply to Anonymous
- 0 +
>>> tanks)
>>under warranty
>info also!)
>best wishes
>Mary
>Mary Haggie
Pleased to hear that Mary, I can't see how it could be anything other than a
printhead failure.
Let us know how you get on.
Tony
Reply to Tony
First we need to know if you ARE and have ALWAYS use Canon OEM ink in
the printer.
>tanks)
>it.
>Many thanks
>Mary
Reply to Anonymous
SOUNDS LIKE AFTERMARKET INK MAKES YOU PRINTER STINK. CALL CANON
SUPPORT. THEY ARE VERY GOOD. THEY WILL PROBABLY SEND YOU A NEW
PRINTHEAD. IF YOU DID USE AFTERMARKET INK DO NOT TELL THEM. SAY YOU
ALWAYS USED THE RIGHT INK.
AFTER YOU GET THE NEW PRINTHEAD BE SURE TO GET A SET OF CANON OEM INK.
COSTCO IS THE CHEAPEST PLACE I KNOW OF. IF IT ALL WORKS OK NEVER BUY
AFTERMARKET INK AGAIN.
>>tanks)
>>it.
>>Many thanks
>>Mary
>>Mary Haggie
>Mary
>at the head!!!).
>Good luck
>Tony
Reply to Anonymous
In article <Rr5Me.839$AT7.169@newssvr22.news.prodigy.net>, measekite
<inkystinky@oem.com> writes
>>>tanks)
>>>it.
>>>Many thanks
>>>Mary
>>>Mary Haggie
>>Mary
>>at the head!!!).
>>Good luck
>>Tony
Well no sooner said than done, rang Canon this morning and emailed my
nozzle check pictures and receipt, had a reply that my new print head
would arrive by courier tomorrow. I hope I find out whether it is the
inks or the print head, will avoid that particular brand of compatible
cartridge if it is them.
Thanks a lot for the interest
best wishes
Mary
Mary Haggie
Reply to Anonymous
In article <hn5Me.834$AT7.403@newssvr22.news.prodigy.net>, measekite
>the printer.
>>tanks)
>>it.
>>Many thanks
>>Mary
Hi, I have expanded on this in my other posts, but I admit that when
the Canon Cartridges ran out I replaced them with compatibles, but if
the problem is with them rather than the print head, then I will not
buy that brand again and try Printrite, I know the Canon OEM are the
best way to go but they are so much dearer, will check out Costco though
thanks and buy them there if they are affordable.
The lady on the helpline did say immediately that it was a print head
problem when I described it though.
best wishes
Mary
Mary Haggie
Reply to Anonymous
Unless you are a very heavy user, and I mean very heavy, it is not work
using aftermarket inks or cartridges as they will cause printhead
problems sooner or later. I suggest under normal use Canon OEM Carts.
I have an IP4000, same printer but with a larger droplet size and I have
never had a problem in 10 months of any kind. I have only used OEM
Canon inks.
>>>>tanks)
>>>>it.
>>>>Many thanks
>>>>Mary
>>>>Mary Haggie
>>>Mary
>>>at the head!!!).
>>>Good luck
>>>Tony
>best wishes
>Mary
Reply to Anonymous
- 0 +
>>>>tanks)
>>>>it.
>>>>Many thanks
>>>>Mary
>>>>Mary Haggie
>>>Mary
>>>repaired
>>>there
>>>versus
>>>colour
>>>at the head!!!).
>>>Good luck
>>>Tony
>best wishes
>Mary
>Mary Haggie
I suggest you be very careful when reading Measekite's posts. He believes that
all head related problems are caused by non-OEM inks, there is no evidence to
support that. Yes you must select good brands of ink whether OEM or not and I
strongly recommend you do not use generic inks, only those that are specificall
designed for your printer (not just Canon) and there are many good makes that
are. The symptoms you described fit a head failure perfectly and clearly Canon
agrees, it is most unlikely that it is an ink or cartridge design problem since
that would exhibit other symptoms.
Measekite will probably yell again and may even become abusive since that is
his way, I suspect he thinks that non-OEM inks caused the Bird Flu virus and
are the root cause of poverty in the world...A kill filter would be a good idea.
Best wishes
Tony
Reply to Tony
- 0 +
>>>>>tanks)
>>>>>it.
>>>>>Many thanks
>>>>>Mary
>>>>>Mary Haggie
>>>>Mary
>>>>repaired
>>>>there
>>>>versus
>>>>colour
>>>>at the head!!!).
>>>>Good luck
>>>>Tony
>>best wishes
>>Mary
>>Mary Haggie
> Best wishes
> Tony
Tony's right Mary. I use only after market inks in my i9900 without any
problems at all.
Measekite is probably the most disgusting person to ever post on any
news group. He lies about after market inks and he has never ever
actually used after market inks and we all believe that he really is
paid by canon to post on this ng.
Don't believe a word he says.
Frank
Reply to frank
This is not a medium issue. Could be the vessle, i.e. the tanks, but
odds are and canon agrees it's the head, or specificly the seals on the
head.
Let's do the math again shall we? We established before that using a
premium refill kit not only save 21% from the start but after using 2oz
of ink you saved 78% vs OEM ink.. In other words.. *ALL USERS* not just
heavy ones save. This is a fact.
As we are dealing with a UK user the numbers are going to be different.
In fact.. a replacement head for UK users isn't the same price as the
printer. This is good and bad for much the same reason.
IP 5000 £157.95 - note this price is a tad high... but given i'm 1/3
the way cross the planet I can't pop in the local shop and see true
street price. But I know for a fact you can buy a printer at that
price including VAT. They spend more than us Yanks, but they do get
the cd printing and nice spiffy auto swiching power supplies.
£135.99 Is probally closer to reality, but I don't know if that price
includes VAT.
The ink... £7.59 for BCI6 CMYpK sounds fair £30.36 sounds
reasonable.
BCI-3e £9.99
Assuming these prices quoted include vat, they definatly include free
delivery £40.35. This reperesents about 1/4 to 1/3 the value of the
printer.
The canon head... I don't know where to get that in the UK, so $90 us
for Mr. 0057. £50.00 soudns fair to me.
http://www.compatible-inkjet-cartr [...] c8ee182768
Prices here are just some random dealer I stumbled upon.
£4.99 for the black and £3.98 for the color. so £20.91 delivered
including VAT.
£40.35 - £20.91 = £19.44 save 48%
Assuming the value of the head is £50.00 and you use three refills and
have to buy a new head... you save £8.32
Assuming the value of the head is £50.00, and use of the 3rd party ink
reduces the life of the canon head from the estiamted 20 refills to
10... you save £194.40 total so a £50.00 head or heck even a new
printer would cost less.
If you print to the estimated life of the head, you saved £388.80.
So while it's *possible* that 3rd party ink might affect your head life
(better, worse, neglable)... I gotta say given these numbers if you
make it passed 3 replacement tanks (i.e. 15 tanks)... you save money no
matter what. This is a fact.. and I didn't shop around to find a great
deal.
Reply to zakezuke
>>>>>tanks)
>>>>>it.
>>>>>Many thanks
>>>>>Mary
>>>>>Mary Haggie
>>>>Mary
>>>>repaired
>>>>there
>>>>versus
>>>>colour
>>>>at the head!!!).
>>>>Good luck
>>>>Tony
>>best wishes
>>Mary
>>Mary Haggie
Do not listen to Tony Da Tiger. He is in the printer business and makes
his money from this kind of stuff. He will admit it when pressed but
then tries to minimize the fact by telling you bullshit. Call him out
on this. Soon you will see that there is a club within this NG and they
all preach the same stuff. Too bad there are so many people having
printer problems many of which are caused by advice by this aftermarket
club.
>He believes that
>support that.
Here comes the qualifier. Just like Microsoft telling you they are not
aware your problem is a bug and then a couple of months later they issue
a fix and tell you it is critical to put it on.
>Best wishes
>Tony
I do think that aftermarket inks put money in your pocket. How many
repairs do you make from this?
Reply to Anonymous
>>>> YOU ALWAYS USED THE RIGHT INK.
>>>> INK. COSTCO IS THE CHEAPEST PLACE I KNOW OF. IF IT ALL WORKS OK
>>>> NEVER BUY AFTERMARKET INK AGAIN.
>>>>>> that has
>>>>>> check it
>>>>>> black
>>>>>> tanks)
>>>>>> even
>>>>>> have
>>>>>> avail.
>>>>>> with
>>>>>> can cure
>>>>>> it.
>>>>>> Many thanks
>>>>>> Mary
>>>>>> Mary Haggie
>>>>> Mary
>>>>> get it repaired under warranty, some warranty service people may
>>>>> be loath to touch it if there are non-OEM ink cartridges in the
>>>>> printer so be warned. (Please no OEM versus non-OEM debates from
>>>>> any lurking zealot, non-OEM ink cannot cause cross colour at the
>>>>> head!!!).
>>>>> Good luck
>>>>> Tony
>>> best wishes
>>> Mary
>>> Mary Haggie
>> believes that all head related problems are caused by non-OEM inks,
>> there is no evidence to support that. Yes you must select good brands
>> of ink whether OEM or not and I strongly recommend you do not use
>> generic inks, only those that are specificall designed for your
>> printer (not just Canon) and there are many good makes that are. The
>> problem since that would exhibit other symptoms.
>> that is his way, I suspect he thinks that non-OEM inks caused the
>> Bird Flu virus and are the root cause of poverty in the world...A
>> Best wishes
>> Tony
> any problems at all.
> Frank
Don't believe a word he says. He is a member of the aftermarket club.
As a matter of fact he is the Vice President.
Reply to Anonymous
Agreed... I thought I offered pretty good proof that all users save
money using bulk inks.. yet he continues to ignore that fact. He
continues to say only heavy users benifit.
The problem is i'm just as skeptical as our resident canon
represnative. I'm willing to believe that use of 3rd party inks in a
thermal bubble jet will affect the print head life. This is a valid
enough hypothesis. But in all sceneros... when the cost savings is 50%
or higher... even if the reduction in life is 1/6th the head life... it
still costs less. This would cover the compatable market.
There might be a good reason to go with OEM, but I don't see price
being a factor at all.
Reply to zakezuke
More rhetoric
>head.
>includes VAT.
>reasonable.
>BCI-3e £9.99
>printer.
>http://www.compatible-inkjet-cartridges.co.uk/section.php/454/0/390a4cfef6b0450daa61d5c8ee182768
>including VAT.
>deal.
Reply to Anonymous
Don't believe a word any of us say. Assume we are all a bunch of
lunatics.
Trust your own observation and reasoning skills... make your own
judgements.
Reply to zakezuke
> More rhetoric
No sir.. .facts.
With all due respect... your elaborate attempts to persuade everyone
into beliving that OEM inks will resolve any issue under the sun are
factually vacuous, questionable in reason, and insincere to the 10th
degree. This is the very defination of rhetoric. I'm not a member of
either the church of the aftermarket inks or the Orthodox Church of the
OEM. I offered pretty conclusive proof that the in cost is lower, the
long term cost is lower, yet you still ignore proven facts and continue
with your rhetoric
You claim that "Unless you are a very heavy user, and I mean very
heavy, it is not work(sic)
problems sooner or later".
Funny thing is... you'll get printhead problems sooner or later anyway.
The canon printhead... thermal bubblejet... is on the low end of the
scale in terms of life. The printer is only rated for a max duty cycle
of 20,000p, or about 20 tank changes. Thermal heads burn out.. that's
a fact.
Assuming your assertion of worth is money.. it's worth it. Assuming
your assertion of worth is time..... you *might* have a valid point
your your self but not for others... and I mean might. What you would
need to do is back up this hypothesis with a fact. How do particular
inks affect printhead life... what is that affect. Keep in mind that a
1/6th reduction in printhead life... as in if you are only able to
print 1600 pages color and black and white... without buying a new
print head... guess what... it's worth it in terms of money. Let the
individual deside if they think it's worth it.
Your hypothesis regarding the ink is not invalid, but needs to be
tested to become even a theory. I will freely admit I don't know the
affect of particular ink on the canon head. This is not a matter i've
seen any facts on. I would welcome any actual information you have on
the subject of different mediums on the canon printhead.
Reply to zakezuke
inkystinky@oem.com says...
>The ALL CAPS advice is from someone with no experience using anything
but Canon cartridges. Since we all know that they work acceptably, there
is no real information in his post.
Reply to Anonymous
In article <YObMe.1563$r54.1339@newssvr19.news.prodigy.com>,
> You make the mistake of many.
inkystinkys advice is based on hearsay only. He has not tried any of the
inks he disparages, he has made no mistakes (and has learned nothing),
but he sure has blown a lot of $$ on overpriced Canon cartridges.
Refilling with a good brand of ink (and several good ones are available,
complete with brand name, batch #, etc.) He isn't aware of this, because
he has never tried any of them. He is a professional naysayer with no
experience, and the manners of a pig.
Reply to Anonymous
Hi Peckerface. You are one I can count on.
Reply to Anonymous
>inks he disparages, *he has made no mistakes* (and has learned nothing),
Reply to Anonymous
In article <1124156223.056285.146830@g44g2000cwa.googlegroups.com>,
>head.
>includes VAT.
>reasonable.
>BCI-3e £9.99
>printer.
>aa61d5c8ee182768
>including VAT.
>deal.
In fact I got 14 cartridges for GBP 17.99, free postage, it was the
cheapest I could find, that works out at only gbp 1.30 each or only 6.50
for a set of 5 which makes the advantage even greater.
Even the Printrite ones are less than 2 pounds each. The Canon originals
are 4 to 5 times more expensive
best wishes
Mary
Mary Haggie
Reply to Anonymous
In article <part1of1.1.A#WvNu1x3RlhvQ@ue.ph>, Tony <?@?.?> writes
>>>>>tanks)
>>>>>it.
>>>>>Many thanks
>>>>>Mary
>>>>>Mary Haggie
>>>>Mary
>>>>repaired
>>>>there
>>>>versus
>>>>colour
>>>>at the head!!!).
>>>>Good luck
>>>>Tony
>>best wishes
>>Mary
>>Mary Haggie
>Best wishes
>Tony
Thanks for the chuckle! I think in any case I will change to Printrite
inks as I used them in my Epson printers for nearly 10 years with no
probs.
I did follow advice from another site recommended here, and mopped up
lots of black in from the sponges where the print head rests, so that
has helped.
Thanks!
Best wishes
Mary
Mary Haggie
Reply to Anonymous
Yes, using a self refill kit... my cost for the color inks is £1.60
and the big black is £2.67 on average taking into account the
refillable tanks in the kit cost £2.21 each... the bulk ink after
that costs me less than £1.56 - big black £0.94 color and small
black. But hey if you can actually find prefills for £2.00/per great.
So £40.00ish vs £10.00ish. Sounds like to me if you make it past 2
refills (10 tanks) and your still printing, even if you must get
another head you are still ahead.. assuming the head price is the same
cross the pond.
Do keep in mind that some of the cheaper solutions may be as light fast
as others... though canon was never known for this in their ink in the
first place. If your putting things on display it might help to do
some homework on other users who have at least done a windowseat test.
But on the other hand... given the fact that i'm spending round and
abouts of 2 pounds for my tanks and ink... and i'm pretty pleased so
far with it's quality and lightfastness... it's reasonable to assume
that 2 pound solutions could be decent.
Lyson i've heard is excelent but tends to cost as much as Canon OEM...
but are reported to be lightfast for 25years or so under normal display
condtions under glass. Not great but better than canon. Based in the
UK IIRC.
Cartridge World I don't know what ink they carry.
This is my limit of what I know about the UK market.
But if what you are using makes you happy.... go with it. Nothing
worse than a network full of jarheads that are trying to make
assumotions what you needs.are. While i would reccomend visiting
http://www.nifty-stuff.com/forum/viewforum.php?id=12 and asking about
the options.. I doubt you can find anything priced lower than you
already found.
Reply to zakezuke
In article <1124191478.137423.53340@g49g2000cwa.googlegroups.com>,
>cross the pond.
>UK IIRC.
>already found.
Thanks I visited the forum you mentioned yesterday and found it very
informative indeed with lots of links, one of which I followed to mop up
all the black ink on the sponges inside the printer.
I don't do anything too important print-wise, just lots of greetings
cards and printing graphics for cards and hundreds of card inserts for
the ladies at my craft club, but it uses a fair amount of ink!
you have been very helpful thanks again
Mary
Mary Haggie
Reply to Anonymous
- 0 +
In message <1124164520.500224.19820@g43g2000cwa.googlegroups.com>,
>a fact.
Is that all? That's a scarily small number? The first colour machine I
had was an Epson Stylus 600 (excluding a second hand HP 500c which was
pretty lousy) and I think that the manual reckoned its life was around
75,000 pages.
Timothy
Reply to ME
>>head.
>>includes VAT.
>>reasonable.
>>BCI-3e £9.99
>>printer.
>>aa61d5c8ee182768
>>including VAT.
>>deal.
>best wishes
>Mary
Happy Clogging
Reply to Anonymous
>>>>>>tanks)
>>>>>>it.
>>>>>>Many thanks
>>>>>>Mary
>>>>>>Mary Haggie
>>>>>Mary
>>>>>repaired
>>>>>there
>>>>>versus
>>>>>colour
>>>>>at the head!!!).
>>>>>Good luck
>>>>>Tony
>>>best wishes
>>>Mary
>>>Mary Haggie
>>Best wishes
>>Tony
>probs.
>has helped.
>Thanks!
>Best wishes
>Mary
Happy Clogging
Reply to Anonymous
>>cross the pond.
>>UK IIRC.
>>already found.
>Mary
There you have Burtie Furtie aka forofreek. Happy Clogging
Reply to Anonymous
Except pigs don't spam an NG with the same old same old, followed up by
adolescent name calling. Actually, it's more like a six year old's
"manners".
Now that most of us have him killfiled, I look forward to the day when
no one, esp. myself, ever feels a need to even mention him.
John McWilliams
Reply to Anonymous
> 75,000 pages.
This may be true but the epson r800 for example is rated at 25,000
pages, and it costs a wee bit more than the other guys.
Well, you have rated duty cycle and you have reality. There is this bj
2100 of my nieces that after a good head cleaning with windex keeps on
printing. then again she's a very light user.
The canon lists it's duty cycle as being the same as the head in the
american service manual. This makes sense as the value of the head is
close to the value of the printer, and a printer comes with a full set
of ink. Logicly speaking if you need both a head and ink.. $60 ish and
$50 ish.. not to speak of out of warranty diaper replacement... average
joe user would save money with a new printer. Odds are anyway.
My point.. really I was trying to make one... the thermal head while
being pretty good doesn't have an unlimited life in the first place...
and head failure can happen and is expected to happen after about
10,000p of black and 10,000p of color there and abouts.
Reply to zakezuke
"zakezuke" <zakezuke_us@yahoo.com> wrote in message
news:1124191478.137423.53340@g49g2000cwa.googlegroups.com...
cross the pond.
UK IIRC.
>They use inks from OCP (largest manufacturer in Europe) and also
>Formulabs(sensient inks).
already found.
Reply to Anonymous
- 0 +
Stick Stickus wrote:
> Once again you respond with insults when the rubbish you spout is
> disproved. When you grow up maybe then you will be able to formulate an
> intelligent response although I doubt it.
> Stick
Ha...I see this moron measershits trash in your reply. He's the sickest
wacko on the web.
Kill file his mentally demented ass as I have and be done with the idiot.
Frank
Reply to frank
Took a while to find your reply, I was asking what the hell was this
man quoting my entire post for. While i'm not an old school posting
snob.. I could care less about top or bottom posting... but the method
you selected to quote me and add something isn't easily understood.
But yes, I've heard they used OCP and Formulabs inks. I don't know
this for a fact, nor do I know what you'd expect to find in BCI-6
refills. Is this company exclusivly in the business of refilling old
tanks or can you buy prefills?
Reply to zakezuke
>> an intelligent response although I doubt it.
>> Stick
> Ha...I am the sickest wacko on the web.
> idiot. Frank
Reply to Anonymous
Apologies for the confusion!
You buy oems, pre-fills, compats and get yours refilled.
Regards
Stick, Oxford, UK
#Remove the 'at' and the'dots' to reply
news:1124265137.145160.37490@g44g2000cwa.googlegroups.com...
Reply to Anonymous
- 0 +
The ip5000 now three months old and never wanted a head check or
clean, I do use Canon ink at the mo, some days it's not been used and
still prints perfect - sheer bliss compared to the Epson which clogged
on the 2nd day, the replacemnt clogged on the 4th day and thats with
Epson inks.
I am also very temoted to use 3rd party inks but so pleased with the
Canon I seem to stuck with Canon inks.
Whats lacking in this forum is a 'sensible' debate of which are 'good
inks' and 'good cartridge' brands to buy, up til now there's just
piffle about after market ink verus OEM inks post after post after
post after post.
There must in this hi tech world of after market inks be bad brands
and good brands, or is it the fear of god of getting sued...?
I used Epson inks for the Epson and they still clogged, I used Canon
ink for the Canon and still it ain't clogged in 3 months, so do I
stick with Canon ink or try any other?
I asked this question a couple of times which no one seems to be able
to answer, I would have expected someone to say, "Oh, my printer
clogged with this but it did'nt clog with that".
Davy
Reply to davy
More power too you... if you are happy your happy. It's not foolish to
use a product and make a judgement that it's OK for your needs. Too
many people around here forget this... and tend to believe that their
way is the only way.
> post after post.
I couldn't agree with you more. Unfortunatly just about every post...
just about every one ends up being a debate about OEM vs aftermarket.
But hey... by all means start a thread on the subject. It's starting
to calm down as users get killfiled, they can rant on as long as they
want.
The information you are looking for is scattered among many posts. It
would be nice to start a tread listing all the manufactors, suppliers,
brand names and whatnot in a singular thread.
The only suit I know of was the priterite suit... and I believe that's
because they said "epson" on the chips offered for epson printer so
when the printer would read the chip, it wouldn't complain it was not
epson ink every damn time you printed something.
Generally speaking you can't really sue someone for speaking the
truth... well you can. I can for example say X brand causes clogs...
and X company could in theory sue me. The burden of proof is on them
whether they suffered as a result of my claim, but the burden of
whether it was a true statement is on me.
I'm most pleased with the refill kit offered by inksupply.com. The MIS
label so far has been consistant in color... and not a single clog
using roughly... probally 2oz by now of color. I'm still on the bci-3e
OEM cart that came with the printer.
http://www.neilslade.com/Papers/inktest.html
I was also pleased by the epson ink by the same company, and the r200 I
used it on worked just dandy for 6 months. It finally got sent to the
shop due to being over full with ink. But oddly enough I got a clog on
the OEM ink, and switching mediums cleared it up, spewed out that clog
on one of my dvd covers.
I've not done enough experimenting to be able to say this ink clogs
that printer. Like your self I was pleased with a given product and
plan to stick with it. I am curious about Mediastreet, formula labs,
and lyson inks... but i'm lazy.
Reply to zakezuke
Then you Stikus them up your ass
Reply to Anonymous
That is a good decision.
>>post after post.
That is impossible. For there are no brands. Prefilled carts haved
vendor labels and they will not disclose the mfg/formulator name
signifying the brand. You are dealing with a bunch of whores.
>want.
There are no brands.
Reply to Anonymous
In article <Cu3Ne.467$zD3.179@newssvr29.news.prodigy.net>,
Canon carts have Canon vendor labels and they will not disclose the
mfg/formulator name signifying the brand. You are dealing with a bunch
of whores.
Reply to Anonymous
- 0 +
> of whores.
Absolutely! None of the major printer companies will divulge that
information. It is considered trade secrets.
You can get more info from after market ink vendors than you can from
those corporate whores.
That's a known fact.
Frank
Reply to frank
>> bunch of whores.
> Frank
DO NOT BELIVE THIS LYING JERK OF AN IDIOT.
Reply to Anonymous
>>> bunch of whores.
>> Frank
Anyone who takes the time to read back thru this news group postings
will quickly discover that you and not mr frank are the one who is
deceitful and full of vile hatred for the truth. I can't conceive of
anyone believing anything you say or have said for a long time. You and
the truth are not acquainted.
Jon B.
Reply to Anonymous
In article <rEwNe.630$GV7.375@newssvr25.news.prodigy.net>,
> >> bunch of whores.
> > Frank
I belive him. (or should that be "I belive heem"?) My ESL is a little
(leetle?) rusty.
Reply to Anonymous
Another Putz
>>>> bunch of whores.
>>> from those corporate whores.
>>> Frank
> and the truth are not acquainted.
> Jon B.
Reply to Anonymous
>>>>bunch of whores.
>>>Frank
>(leetle?) rusty.
Your Pecker-Bloomer is a lettle rustry
Reply to Anonymous
measekite wrote:
> Another Putz
>>>>> bunch of whores.
>>>> Frank
>> Jon B.
Calling me names does nothing for your credibility. In fact it only
serves to bolster mine.
Jon B.
Reply to Anonymous
Previous
1 2
There are 505 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
