Will my motherboard work with a SATA 3 Gb/s hard drive?
The reason I am asking this is because I found an 80 gig SATA 3 Gb/s hard drive on newegg for $40. I found a 40 gig SATA 1.5 Gb/s for the same price...SO the motherboard I am getting says it supports SATA 1.5 Gb/s, can I use a 3 Gb/s Hard Drive? I would assume if you could it would only run at 1.5 gb/s wich is fine because It is still cheaper.
3 answers Last reply
More about will motherboard work sata hard drive
  1. Check the specs on the drive. Probably the tech manual on the mfg's web site. My WD drives have a jumper to force them into SATA I (1.5) mode.
  2. The disk will be backwards compatable. If you are worried about it, get the 1.5G disk.
  3. It will work, but maybe you will need a jumper
Hard Drives SATA Motherboards Storage
