front panel audio connector
  • Sound Cards
  • Cases
  • Front Panel
  • Connection
  • Components
Last response: in Components
September 5, 2006 2:59:54 PM
Hellow.i have a little problem with my mobo and case.I bought soprano case and i want to connect the outpouts connection of the case in my mobo.The mobo is asrock k7vt6.How i must connect the mobo layout with the case layout?
This is the fotos from manual of mobo and from case manual Mobo
case
Please if anyone knows how to connect as tell me
PS sorry about my broken english english.
More about : front panel audio connector
September 5, 2006 5:24:26 PM
The pictured layout seems typical. What kind of case do you have? I'd be somewhat surprised if it did not have connectors what would fit what you have pictured.
September 5, 2006 7:55:26 PM
My case is THERMALTAKE VB1000BWS SOPRANO
September 5, 2006 9:28:51 PM
Quote:
i'm assuming you get lots of little connector all split up fromt he audio ports.
if so it is just like connecting a USB port to the Mainbord. wither their will be little writing on the connectors which correspond to what is written on the mobo beside the connectors or it will tell you in the case manual.
it might be a fiddly job depending on if the connectors are fixed to gether in a group or if they are stuck to gether but some long nose pliars helps alot from my limited experience of front ports.
Hell, Strange is absolutely correct, AFAIK.
