So, I went ahead and started OCing and it's been very stable at 2.3GHz for a while now. It idles fine and during heavy use it runs fine. My 3DMark 05 score has seen an almost 700 point boost and my temps are pretty much the same as they were when it was stock.
But I've been running into a odd restarting problem. Whenever the computer goes to shut down, it'll log out of Windows, the GPU shuts down (because I get no image) and right before it's supposed to turn off everything else it freezes. This only happens during some reboots.. not always. It shuts down fine and starts up fine (except when it freezes during restarts, then I just have to tell it to ignore the issue.
My specs are:
CPU: 230MHz x10 multiplier, 4x htt, 1.30V
Memory: downclocked from DDR2 800 to DDR2 667, currently running at DDR2 766 (or 383Mhz), 1.9V
Here is some info that might help.
http://img208.imageshack.us/my.php?image=sysinfonh9.jpg
Could this issue be due to my OC? What tests can I try to see what the problem is? I've done memtest (4 hours) and Prime95 (stress test for 1 hour, 40 min) and didn't get any errors.
========Previously==============
I read that there were a few ways to OC a AMD system so I decided to try upping the frequency as it seemed to be the most simple way. I want to hit 2.4 with stock cooling and maybe a slight voltage increase if necessary but I'll settle for less if I can't keep my system stable.
Currently my specs are as follows (via CPU-Z).
FSB (frequency): 200MHz
Multiplier: 10x
DDR2 800 5-5-5-12 @ 200MHz
So I have a ratio of 1.0:1.0 ratio CPU to memory frequency.
I reduce the DDR2 667 by decreasing the clock to ~166MHz and increase the FSB to 240MHz.
Now I have a ratio of 1.2:1.0 ratio CPU to memory frequency.
With a 10x multiplier, that should give me 2.4GHz (240MHz x 10) CPU speed and an memory speed for about ~199MHz (166x1.2) or DDR2 796 effective right?
Concerns:
1. Am I thinking straight? Or am I completely lost and out of order?
2. Does this sound safe? If not, what components will be stressed the most?
3. Do I have to change the HT frequency or anything like that? I hope not as I don't understand it.
4. How do you know when to change the HT? (Not really important if the answer to #3 is a no).
5. I'm guessing since I'm fairly close to my memory's rated 800 speed that I shouldn't reduce the timings at all?
Thanks in advance. Hope I got this down and if not, hopefully you guys will straighten me out.
My specs are:
Multiplier: 10x
Concerns:
