Archived from groups: microsoft.public.win2000.file_system (More info?)
I am now gettting a message when I start the computer that certain system
files have been updated with non-kosher versions, and that "for stability
reasons" I should put them back to what they should be. It recommends to
insert the Windows 2000 disk.
When I do that, it says that it cannot upgrade a version SP4 to a version
SP3. It also alludes to the fact that my O/S disk is an upgrade, and that is
also a problem somehow.
So, that's my question - How do I check the file system or cause the signed
versions of files to be correct?
Insert the Windows 2000 CD-Rom, dismiss the warning and from the 'Run' box
sfc /scannow
or you can also just reapply SP4
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
is
signed
| Many thanks,
| Ian
