In part 3, the guide has a number of voltage adjustments that are of the form +.xv from the default.
How do you figure out what the default is? I know how to look up the voltage on my RAM, but I don't know what the MCH, VFSB, or ICH defaults were.
Also, I couldn't figure out what the MCH was -- there doesn't seem to be a setting in the bios that was obviously that.
I set my core voltage to 1.4V as per the instructions, but it seems that my vCore actually is 1.35V (as reported by both the bios HW monitor and core temp).
I purchased OCZ Gold Series 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 667 (PC2 5400) Dual Channel Kit System Memory - OEM
http://www.newegg.com/Product/Product.asp?Item=N82E16820227078
which says it is 1.9V on the newegg site. Does this mean I should set my ram voltage to 2.2 to 2.3V (I'm OCing to 333mhz first as per the guide)
The timings for the RAM are supposed to be 4-4-4-12. There was two other settings that I wasn't sure what to do with. The guide said to leave them at defaults, but I don't know what the defaults are. The ASUS bios seems to just put them at the worst possible settings. I ended up leaving the SPD timings in place which according to CPU-Z is getting me: 4-4-4-11 timing.
Curiously enough, Cpu-Z is reporting that I have PC5300 (332.9mhz) RAM. I'm not sure why that isn't showing as PC5400... (a rounding error?)
It looks like in spite of these issues, I am @ 333... but I don't know if I am stable yet though. I'd still appreciate some advice as I'm hoping to push things farther.
My CPU temperature is 46C at idle. Is that high?
