I got a new core2duo system and i accidently plugged the power cable to my floppy drive incorrectly. when i turned the pc on the drive started smoking. i turned the pc off and thats when i realized i plugged it in wrong. i inspected the power cable that was connected to it and it was melted. i detached the floppy drive. i was scared to turn the pc back on with that power supply after what happened but i did it anyways. it seemed like everything was loading fine till it got into windoze the screen was all messed up.
so i ended up swapping the powersupply to get it to work.
so here is my question. did it do any damage to my cpu, mobo or memory when it was smoking? after the swap everything seems to be ok. so was the damage only to my powersupply?
i started monitoring my voltage levels is 1.0-1.2 for cpu core voltage normal?
