CAN\'T open application SilverKeeper Installer because Power PC applications NO
Can't open Application SilverKeeper Installer because Power PC applications NO Longer Supported - this is message I get when try to install SilverKeeper 6.5.4 on LION
OR - when I click on installer I get " Sorry, SilverKeeper cannot be run from a LOCKED volume " .
All I want is to open my LACIE hard disk and get access to saved files.
THANKS
2 answers Last reply
More about open application silverkeeper installer power applications
  1. It's dead http://www.lacie.com/silverkeeper/
    If you want it you'll have to install a pre-lion copy of OS X, depending on the machine and your requirements this could be as the main OS, a VM or as a second OS via Bootcamp.
  2. :hello: THANKS JUSTSOMEJOE .....
Installer Power Mac OS X
