When I run cpuz it tells me the memory is running single channel. I didnt see anything in the bios to change this. I installed both sticks in channel A. Is this a problem with the memory and the mobo, or is there something I am missing in the bios settings?
You may want to try switching the ram positions. Try every possible configuration... It couldn't take long, 5-10 minutes maybe. Just stop the boot process and check it in the bios. This will (hopefully) solve the problem. If not, its more serious....
Thanks all for the help. When I think about it now it was pretty dumb of me to put both sticks in the same channel. I guess dual CHANNEL should have given it away. I moved the second stick to the other channel and now I'm screaming along with my memory in proper dual channel mode
errr... frankly here, I'd throw a 'RTFM', manuals usually describe memory sticks recommanded placement configurations - to be read carefully when you build your system.
