Closed Solved
Problems win 7 64 bit
I am using Win 7 64 bit OS. Every time I try to drag something, in any one of several programs (e.g. Autocad, Excel, Word, Solitaire, etc.). The problem started after I had been using the OS for several months. Any one elsehave this problem?
18 answers Last reply Best Answer
More about problems
  1. What problem ? Can you elaborate a bit more ?
    Yes? Then what?
  3. Herr_Koos said:
    Yes? Then what?
    My thoughts exactly... lol... this is an epic example of tech forum awesomeness... sometimes you just gotta laugh.
    Sorry, I left out the good part. Every time I try to drag something, it moves a tiny bit, then I get a dialog box (Repeat move, cut, copy, paste, etc.) and dragging stops. I've also lost several unsaved files where I click on a command, and the program dissappears. I'm also missing several saved files from Autocad. Virus??
  5. Are you dragging by right clicking ?
  6. No, dragging by right clicking (as I always have).
  7. Sorry again, I meant LEFT clicking.
  8. It's not unlikely that you've picked up a bug of some kind. Is your PC protected?
  9. Also, what happens when right clicking ? No, seriously.
    Could be a virus perhaps or a bug.
  10. Right clicking works ok on desktop, asks if I want to move or copy at destination. Right clicking has no effect in Autocad, Solitaire or Excel. The problem is more pronounced dragging right than dragging left. I have run malwarebytes scan and spybot, no infection found. I have had resident Norton antivirus on the machine since startup July 2010.
  11. Did you run a full scan of your system ?
  12. Yes, I ran full scan with both programs, as well as Norton. No hits.
  13. Best answer
    Have you tried re-installing windows ?That seems like the only way for now, I guess. Backup all your files before this.
  14. Reinstalled Win 7 (Whew!), finally got my modem & router working again, but still have the dragging problem. Can't drag in desktop, Excel, Autocad, Solitaire, etc. I can cut and paste to move items. What a drag.
  15. This could be a virus or bug from a email or so.
  16. After restarting and "configuring windows updates", problem went away. Thanks
  17. Best answer selected by bkh1.
  18. Good Deal!
Solitaire Windows 7
