Tom's Hardware > Forum > Smartphones & PDAs > Windows Mobile > BT Problems with Async
Forum Smartphones & PDAs : Windows Mobile - BT Problems with Async
Archived from groups: microsoft.public.pocketpc (More info?)
I just got a new BT Adpater and it will connect to the pc fine and vice
versa but the activesync wont work... could someone reccomend a web site
where there could be a solution or even better post a message to me
Sponsored Links
Hi,
From what i remember there are two steps you need to take...
1. Enable active sync software on windows to accept serial connections:
-in activesync click file > connection settings
-tick the top box, allow serial cable or infrared connection to this COM
port
-you then must select the relevent com port for your bt adapter (this is
the incoming port) you can find this information through your BT utility -
if XP in the control panel
2. You need to tell your PDA you want to sync using your BT
-Start > Bluetooth Manager
-New connection
-ActiveSync via Bluetooth
-now just follow the BT setup wizard
Hope this helps!
"Deep Thought...at times..." <DeepThoughtattimes@discussions.microsoft.com>
wrote in message news:066A7403-E8A8-4FB4-871D-175610928599@microsoft.com...
Reply to Anonymous
You can check our Geekzone Bluetooth Guides (link below in the sig)
Mauricio Freitas, Microsoft MVP Mobile Devices
http://www.geekzone.co.nz
http://www.geekmac.com
Bluetooth guides: http://www.geekzone.co.nz/content.asp?contentid=449
Geekzone Software Store: http://www.geekzone.co.nz/store
Reply to Anonymous
There are 787 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
