Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Help Cannot get Media Player to work
Forum Windows XP : Windows XP General Discussion - Help Cannot get Media Player to work
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I recently upgraded my Windows XP Pro machine's Media
Player to vs10. I also installed another software program
because I could not get Media Player to play an AVI file.
The program I tried did not work either, so I removed it I
then tried Player again and it would not work at all. I
could not even find it so I tried to do a Windows Update
again and it looked like it is going to finish the
install, but I get an error message. Windows Media Player
is incompatible with this version for more details view
this web page. http:/go.microsoft.com/fwlink/?
linkID=28004. When I try this link I get an error no
matching entry. After I close all the dialog boxes it
says the update was successful. However it is not done an
install.
I even downloaded version 10 and tried to just do a
straight install and it does the samething. It is
incompaitible with this version. I tried going to Control
Panel where you can add windows components. I tried this
from the Control Panel, this did not work it is grayed out
showing 0 Bytes. I also tried putting the Windows
installation CD. It shows 0 bytes where should show the
size. I am guessing it thinks it is already installed so
it will not let me. However it will not let uninstall it
either. I was hoping If I could get to an older version I
could then Update it again.
Since I could not get any version of Media player to
install, I tried a System restore to date when everything
worked. This did not work either. Is there anything I
can do to install older version of Media Player? If I can
get so version of media player working I can then upgrade.
Sponsored Links
Hi,
WMP10 can be uninstalled via Add & Remove, but it's not under Windows
Components. It should be in the main list, but you must have the "show
updates" box checked at the top to see it.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"treasuredphotos" <anonymous@discussions.microsoft.com> wrote in message
news:080501c4c488$07e94160$a501280a@phx.gbl...
> install.
Reply to Anonymous
There are 659 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
