I recently built a system based on an AMD X2 4200 (full specs below). I am getting a less than perfect display, in that there are some spurious blue-ish vertical lines appearing on the display. This is especially noticeable on a black background, for example, I get blue dots and small vertical lines around the Windows XP screensaver.
Suspecting the graphics card, I changed it. When this didn't cure the problem, I tried the graphics card in the other PCI-E slot, to no avail. I then swapped out the motherboard for an identical model, assuming that this could be the only thing left that could be causing the problem. This hasn't cured it, unfortunately! I've also tried my monitor on another machine, and the monitor isn't at fault.
I'm completely baffled, so any suggestions will be very gratefully received.
Many thanks
Mark
System:
AMD Athlon X2 4200
1GB (2x512MB) Corsair Value DDR667
Asus M2N32-SLI Deluxe Wireless Edition
Jeantech 600W PSU
Samsung Spinpoint 300GB SATAII NCQ HDD
PNY NVidia 7300GS Graphics
Many thanks
Mark
System:
AMD Athlon X2 4200
Jeantech 600W PSU
