Archived from groups: microsoft.public.pocketpc (More info?)
I was wondering if anyone else had encountered this problem or knows a
fix for it.
I've recently purchased a Sandisk 256MB SD WiFi card to go with a Medion
MDPPC250 PDA. I use the PDA primarily for use as a sat nav system for
the card, but I liked the idea of using WiFi for internet browsing etc
at other times. The problem is that whenever I install the drivers for
the WiFi card (latest version off Sandisks support web site) the WiFi
card works fine, but it somehow stops TomToms voice prompts. The PDA
still plays WMV/WMA files with media player, but it will not play WAV. I
did the obvious and copied the files to a PC to make sure the files
weren't blank, plus I re-installed TomTom to see if that helped but
still the same problem.
