I just built a new storage/home theater rig. specs as follows:
Asus M2N32-SLI deluxe
AMD 3800+ X2
1 Gig Geil pc2-800 ddr2
eVga geforce 6600 GT 128mb (from old SLI setup, just single card now, waiting for directx 10 stuff before upping this)
Thermaltake toughpower 700 power supply
6xseagate 320GB 7200.10 drives in Raid 5 1.45TB volume
LG DVD burner
Custom enclosure to fit my AV rack
So I get this puppy up and running and everything is good. fast boot, lots storage, etc. But i notice that it takes forever to do the following:
1. transfers over my gigabit lan, which moves a large hdtv file between my other two computers in about 15 minutes, takes about 4x as long.
2. disk to disk copies - i.e from the raid to the raid to make two copies of a file, so one can be safely edited - take forver.
3. joining .TS (mpeg 2 transport stream) files takes 4x as long as on an athlon 64 3500+ - albeit with 2GB of ram. Also, the cores barely register anything during this so it appears to be more HD limited.
I have no boot issues, no BSOD's, no fluctuations. only software installed is windos xp home, VLC, diskeeper, AVG antivirus, and firewall. I have done an initial defrag run thattook several days - also seemed very sluggish but I thought maybe diskeeper just needed to anylyze everything close first time through - subsequent runs have remained slow. I made sure to disable AVG scans and diskeeper scans when doing disk intensive ops but there is still a huge lag compared to older system.
Temps are all low in the mid to high 30's and with prime 95 two instances the cores stabilize at 51 deg C, so overheating is not an issue. The disk array has two 12cm flans pulling and pushing air over them and they are cool to the touch (yes I ground myself first).
I thought 6 new HD's in raid 5 should give me decent speed, but it appears it is etremely sluggish. anyone have any ideas that i should start to check?
Thanks!
AMD 3800+ X2
LG DVD burner
Thanks!
