Tom's Hardware > Forum > Smartphones & PDAs > Windows Mobile > Problem with Bluetooth Headset
Archived from groups: microsoft.public.pocketpc (More info?)
I have a Bluetooth enabled IPAQ 4700. I am trying to pair my Mobile headset
M2500 with Bluetooth and am not able to do so. My Bluetooth is on in the
"Hands-free/Headset setup" screen, but showing no devices listed when I
activate the Bluetooth Connection Wizard. I am doing everything that the
headset setup instructions requested. Please help
Sponsored Links
On Sun, 16 Jan 2005 09:06:42 -0600, news.dallas.sbcglobal.net
> headset
Is there a light blinking on your headset? Are you sure that headset is
on?
Brad Isaac
editor-in-chief, www.pocketpcaddict.com
Developer, Achieve-IT! Goal Setter for Pocket PC
Reply to Anonymous
Are you sure the headset is in discoverable mode? In most cases you have to
turn it off. Then turn it on again and keep the button pressed until you
hear a beep. Some LED will blink quickly. During this time it can be
discovered.
As for PIN, most headsets default to 0000 (this is a four zeros number).
Mauricio Freitas, Microsoft MVP Mobile Devices
http://www.geekzone.co.nz
http://www.geekmac.com
Bluetooth guides: http://www.geekzone.co.nz/content.asp?contentid=449
Geekzone Software Store: http://www.geekzone.co.nz/store
"news.dallas.sbcglobal.net" <tamatora@swbell.net> wrote in message
news:OP1U%23z9%23EHA.3368@TK2MSFTNGP15.phx.gbl...
Reply to Anonymous
Had that headset with a t-610. in order to pair it I had to press and hold
the button on the headset (only worked after charging the new headset for a
while) then entering the bluetooth menu on the phone at the same time and
discovering the headset. The phone would not recognize the headset if the
phone was already in the bluetooth menu before I pressed the headset button.
headset
Reply to Anonymous
There are 1254 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
