About 2 weeks ago I excited ordered the parts I thought would make a great, overclockable, and quiet Conroe system:
- Asus P5B Deluxe/WiFi
- E6400 processor
- Zalman 7700 cooler
- Seasonic 430W PSU
- GeForce 7600GS (silent and helpfully limits my gaming
- 2 x 1GB RAM AmpX/Wintec 5400
- Antec Solo case
- Sony DDU1615 DVD Drive (quiet DVD reader)
- Pioneer DVD+-R/RAM
- Existing 250 GB PATA Seagate drive
- New 320 GB SATA Seagate Drive
** Step 1
When I (finally!) received all the parts from Newegg, I put them together. Everything seemed to power on, all fans running, MB LED are lighted, but otherwise nothing happened, no POST, no nothing. I checked and rechecked that all the connections were secure, etc. without success. Although my monitor has always worked, I tried the D-sub cables and tried another known working monitor in case it was a display problem. No dice.
I called Newegg and ultimately Asus to investigate. I figured the RAM or the MB would be the problem. The Asus tech had me clear the CMOS (battery removal plus jumper reset), remove the RAM, then the CPU. I do not have a PC speaker in my case, so he had me plug my computer speakers into the sound output on the motherboard. Even without RAM and/or CPU the MB did not produce beeps. BUT, I wasn't (and am still not) totally sure if the MB would beep without a PC Speaker. The Asus tech concluded that the MB was dead so I RMA'd it back.
** Step 2
After waiting many anxious days I received my replacement P5B Deluxe/WiFi and I figured the problem would likely be resolved. With great anticipation I turned it on..... no such luck: no POST, no beeps when RAM removed, etc. Everything appears to power up just as before, but nothing else. All connections and basic things seem ok.
** Step 3
I figured at this point that it was almost certainly the RAM, since many people seem to be having RAM compatibility problems and this would prevent POST. Today I picked up for testing 1 GB of Kingston RAM KVR533D2 that is on Asus' list of QVL RAM for the P5B Deluxe MB. I picked up some Corsair value RAM 1 GB for good measure. I tried testing with each of these RAM DIMM's, Kingston, then Corsair, then my original AmpX/Wintec and still no POST in any scenario. At the same time I picked up an ATI X1300 just in case the video card was the problem. Still, no POST.
** Step 4
The system at this point is just the Monitor, Case, PSU, MB, CPU and fan, and Video card. Since I'd replaced everything other than the CPU, I just picked up a new CPU, the same model E6400. Again, no POST, no nothing other than powering on.
I've had the PSU running with my old system (Athlong 1.33 GHz - old I know), so I don't think that's a problem, besides everything seems powered in the system. The monitor I know works. The case does nothing functional, and every other component I've replaced. Yet, the system still will not POST.
The only thing I can think of is that the case is shorting something so I will try building the system outside of the case, but if that doesn't work, what do you all recommend? Is anyone else having this hard a time? I am seriously frustrated and not sure what to do next. Thanks for any help/advice.
