Tom's Hardware > Forum > Computer Peripherals > Printers > Where (UK) can I purchase replacement print heads for Epso..
Forum Computer Peripherals : Printers - Where (UK) can I purchase replacement print heads for Epso..
Archived from groups: comp.periphs.printers (More info?)
I am looking for a stockist in the UK who can supply print head replacements
for the Epson 440. If anyone has had experience with a good supplier then
please share the info with us all.
Thanks in advance
Terry
Sponsored Links
You could try www.expressterminals.com
"ngreplies" <ngreplies@tdrd.freeserve.co.uk> wrote in message
news:dfagt4$5ph$1@news7.svr.pol.co.uk...
replacements
> Thanks in advance
> Terry
Reply to shooter
It will probably NOT be worth your while to replace the head of a 440,
which is Epson's low end printer. The head will be costly and replacing
it involves changing voltages in the firmware which requires a software
program not typically available to end users.
Art
> Thanks in advance
> Terry
Reply to Anonymous
thanks for the feedback Arthur.... the 440 is destined for the landfill
then.
I had hoped to revive it, but as you say it involves twiddling with
voltages, then I could well be wasting my time.
Terry
"Arthur Entlich" <e-printerhelp@mvps.org> wrote in message
news:NdbSe.359295$5V4.315516@pd7tw3no...
> Art
replacements
then
> > Thanks in advance
> > Terry
Reply to Anonymous
What makes you think the heads are U/S and not just in need of TLC.. I would
take a risk of dismantling the unit to remove the heads ( minus cartridges )
and leave the face ( nearest the paper surface) soaking in several layers of
kitchen towel soaked in print head fluid.
Very gentle wiping using just soggy kitchen towel soaked in fluid at times
during the long (24 hour) soak will help free any debris. Unfortunately you
can't tell if its fully recovered without fitting new cartidges.. Best of
luck
Reply to Anonymous
BTW, how do you know the head is dead, maybe it needs a good cleaning,
I can offer help for that in private mail.
Art
> then.
> Terry
>>Art
> replacements
> then
>>>Thanks in advance
>>>Terry
Reply to Anonymous
Before removing the heads and cartridges, you might wish to email me, as
I can send you some helpful hints on Epson head clogs which might get
you back up and running.
Art
> luck
Reply to Anonymous
The head is dead because it's in a lot of bits and the head has come apart
from the strip connecting to the circuit board... trust me... ITS DEAD!
I read an article that said if you remove this clip it will destroy the
head.
Well I did and it is.
T
news:RWzSe.76017$Hk.37838@pd7tw1no...
> Art
> > then.
> > Terry
> >>Art
> > replacements
> > then
> >>>Thanks in advance
> >>>Terry
Reply to Anonymous
Fair enough, your description certainly indicates a very dead head.
Sorry, I thought I may be able to help revive it, but not from that
state ;-)
Art
> head.
> T
>>Art
>>>then.
>>>Terry
>>>>Art
>>>replacements
>>>then
>>>>>Thanks in advance
>>>>>Terry
Reply to Anonymous
There are 1247 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
