Tom's Hardware > Forum > Storage > Hard Disks > partition problems
partition problems
Forum Storage : Hard Disks - partition problems
hey all . I could really use some help. I have two HD's, one 80 GB seagate, and one 250 GB seagate. Unfortunately, due to horrendous fuckups in the past, i've had to make two partitions in the 250 GB HD, and 2 in the 80 GB HD. As you know, making partitions is effectively the best way to waste away 20% of ones storage capacity. I want to know if anyone can tell me how to RE-PARTITION the HD's.I wish to at least remove the partition in the 250 GB hd, without reformatting the thing. I have about 170 to 180 GB of free space in it.
The 250 GB HD is formatted in NTFS whereas the 80 GB HD has one partition in FAT 32 and one in NTFS.
Also, any other storage tips etc. would be more than welcome.
Sponsored Links
It's pretty easy with partion magic. Just empty one partion, delete the empty and resize.
Reply to ms2005
thanx.will try it out.
Reply to mani_chattha
There are 1184 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
