Archived from groups: comp.periphs.printers (More info?)
The non-profit organization I work with has an HP1300 that has been
diagnosed (by a printer repair shop) as having a damaged heat fuser roller.
An new one is $200 plus labor for replacement. Is there a way for us to
repair this at a substantially lower price. I am sure we would need a good
repair manual showing how to dismantle and re-assemble the printer, as well
as find a much lower cost for the roller.
>Thank You,
>Gordo
Sounds like the price you have been quoted is for a complete fuser assembly
(Not sure what dollars you are quoting US$ ???).
You can get a service manual from
http://www.fixyourownprinter.com/r [...] /public/hp look for laserjet
1150/1300 service.manual. You will need to register first (no charge).
Then google for a local supplier of the part, you can buy a complete fuser
(110v or 220v depending on your local voltage) or just the roller (more work
involved - see the service manual for procedure). Go to
http://www.partsmart-corp.com/show [...] del=HP1200 for a list of
parts and one possible supplier.
Good luck
Tony
You can order a kit for this purpose for cca $40(35 Euro) + parcel costs.
You got:
Fuser foil + one shot of fuser grease + 5 ml of fuser cleaning solution.
Pozdrav
Adriatic
"gordo" <None@phony.net> wrote in message
news:B4ydnSHz25FiIoTeRVn-sw@seanet.com...
roller.
well
> Thank You,
> Gordo
Thanks. I will look into it.
Gordo
> assembly
> laserjet
> work
> of
> Good luck
> Tony
Can you give me a URL (USA) or are you referring to Tony's message?
Gordo
"Adriatic" <a1@adriatix.hr> wrote in message
newsfh0gh$8ig$1@ss405.t-com.hr...
> You got:
> Pozdrav
> Adriatic
In message <B4ydnSHz25FiIoTeRVn-sw@seanet.com>, gordo <None@phony.net>
writes
Precisionroller.com might give you an indication. I recently had both
fuser rollers replaced on my machine and gave that website a quick
perusal to see if the price I was quoted was sensible (which it was).
This is a Canon machine and it wasn't the official Canon servicers.
