Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > NV Silencer 5 Not Cooling 6800GToc. Need Help.
Forum Graphic & Displays : Graphics Cards - NV Silencer 5 Not Cooling 6800GToc. Need Help.
I'm new to the forums in hope of finding a way to fix a small problem.
Here are my current system specs:
AMD Athlon FX-55
2GB DDR400 Corsair XMS
Gigabyte GA-K8N Ultra-SLI
BFG Tech 6800GToc
Nothing is overclocked.
Using the stock cooling on the graphic card it idles at 64-68 degrees and when I play any type of demanding game it will overheat after a good 5 minutes.
I purchased the Arctic Cooling NV Silencer 5 (rev.2) after reading alot of reviews about it. I also purchased the AC Thermal Compound for this.
I installed the new cooling unit this morning and I am still getting the same problem. Idling at 64 and after 5 minutes into HL2 it overheats and causes the system to crash.
I read mutliple instructions from multiple sites and it seemed quite simple on how to install this, and I did all this with ease. So what could possibly cause the problem here?
Any and all information would be greatly appreciated. Thanks in advance.
Sponsored Links
There are 1118 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
