I have been having this problem getting workgroups to work on certain Win XP Pro computers.
We use a Workgroup at our home office, and when I go through the proceedure to add a computer to a workgroup it works on some computers, but some it does not. The procedure:
In System Properties screen/Computer Name I make a nice logical computer name, and select the Workgroup radio button. I put in the name of the Workgroup.
Then I run the "Set up a home or small office netowrk" wizard with the settings for using a residential Gateway. I run this so I can turn on file and print sharing. Then I reboot.
On some machines this works and the workgroup is found in Network Places and other computers on the workgroup show up as well.
On the machines that don't work, the workgroup does not show up at all even when looking at the Entire Microsoft Windows Network. So they cannot see the workgroup and their own machine does not show up.
However, other computers on the workgroup can see this computer in the workgroup.
I know ther must be some simple thing I am missing, but I havent' found it.
Most of the time I just don't bother using the wizard, because it rarely works on my end (well, most of the time I just scrap all the settings after lengthy troubleshooting steps on M$'s Website).
um... assuming you are not using other OS on the network, I would try the following:
before you begin, uncheck all connection's TCP/IP in network connection/[Name of your connection]/properties except the one you are connecting (sometimes the IEEE1394 and second onboard Ethernet are just plain annoying)
1st comp: do what you did, except do the computer name/workgroup name AFTER the wizard, then write down TCP/IP info on the network connection/[Name of your connection]/Status/Support/Details...
(With all the other computers disconnected) [or just PrintScrn and paste it in Paint]
all other comp: don't bother the wizard. Set the workgroup/name, and set the TCP/IP info individually (if the 1st comp manages to use auto-detect in TCP/IP settings, chances are you can use auto-detect on most if not all comps)
I think file and printer sharing can be enabled individually from somewhere else without the use of the stupid wizard.
and if you manage to picg one comp from another then you are games ready too.
TCP/IP info can be set in
network connection/[Name of your connection]/properties, when you select TCP/IP and click properties
i had the same problem with my network, one computer was able to see the other computer shares but not the other way around, it ended up being my firewall on that one particular computer, after adjusting it to allow traffic from that other computer it worked just fine.
