Archived from groups: microsoft.public.windowsxp.basics (More info?)
Running XPHome with SP2
1) All of a sudden 16 bit programs won't run. When I try to start
them, I get a message box titled 16 BIT MS DOS SUBSYSTEM. The message
reads; "C:\SYSTEM32\AUTOEXEC.NT. The system file is not suitable for
running MS DOS and Microsoft Windows applications. Choose close to
terminate the operation."
2) System Restore will not work. I had the problem a few days ago and
an HP support analyst toald me that it's not uncommon after installing
SP2. He sent me to a website for a patch which enabled it to run
after installing SP2...the patch worked.
I don't know if this issue is also related to SP2.
2. What, if any, error messages do you see when trying to use SR, or won't
SR restore any of the checkpoints?
Will Denny
MS-MVP - Windows Shell/User
Please reply to the News Groups
"Dick Reuben" <dickre@comcast.net> wrote in message
news:msj7p013ovumt4v4p4f3mbtfdef49pj62e@4ax.com...
Patti MacLeod
Microsoft MVP - Windows Shell/User
autoexec.nt is probably missing from your C:\windows\system32 folder
you should have a spare copy in your \repair folder that you can copy over
