I just bought a new logitech multi drive (dvd burner and cd combo) and i took out the old cd burner and installed the new drive.
Smooth sailing all the way until i inserted the cd into the new drive and poof! The cpu crashes completely. It will go to read the cd and after a few seconds it will crash and power cycle.
Windows recognizes the drive it shows up everywhere and the only problem is that it crashes the cpu.
i know the rig im using will support the drive and everything is plugged in properly. Am i missing something obvious or is this a comman problem?
Anything at all will help thanx.
